Parallella Community • View topic - How and where to connect the fan?
Postby aihaike » Wed Aug 06, 2014 6:14 am
Hey,
I'm wondering where should I connect the fan.
I've attached part of my setting.
Thank you,
Éric.
aihaike
Re: How and where to connect the fan?
Postby 9600 » Wed Aug 06, 2014 9:53 am
There are no connections specifically for a fan. You can power one via the mounting hole pads if you . Others have taken different approaches and if you do a you will find relevant posts.
Postby aihaike » Wed Aug 06, 2014 11:47 am
Thank you Andrew,
Will make it and make an other reply.
Éric.
aihaike
Postby maynarde » Thu Aug 07, 2014 3:27 am
I found a nice fan that has a USB Type A connector - I then scrounged up a Type A male USB to Type A female cord and a USB phone charger, Viola! 48C max temperature. For giggles, you can find AA battery boost boards with a USB Type A female connector on them and power your fan off of that. I can run 2xAA for a whole day before having to replace batteries.
Ed
maynarde
Postby aihaike » Fri Aug 15, 2014 8:44 am
Good to know maynarde.
Thank you.
aihaike
