I get the login screen, so it appears to be booting properly. No input devices generate a response at all.
No input devices are working. I have tried 3 different keyboards (Motorolla Lapdock via HDMI, Logitech Wave direct to USB by HDMI port, and via powered USB hub, and a generic Dell keyboard via powered USB hub.) My Dell mouse doesn't even show a red light when I hook it into the USB port. The USB hub I'm using is a Belkin 4 port hub that I thought was on the compliant list. I tried the Lapdock connected only by the HDMI cable. I tried the Lapdock connected by the HDMI cable and a USB cable. The login screen comes up, but no input response. I tried a TV screen with the Logitech keyboard and the Dell mouse. I tried the keyboard and mouse via the powered hub, and each independently without the hub. I powered down and up the board between each switch. All combinations brought up the login screen, but no input response.
I've carefully read and followed all of the directions to the best of my ability. I hooked up a fan (it is working). I power everything up from the same power strip. The SD card image should be done right.
How can I figure out what the problem is? Is my USB port bad, somehow? Are my settings just wrong? If so, how can I fix them without being able to input anything to my parallella system? Basically, how can I fix it directly on the SD card image, if that's the problem?
I'm getting very frustrated.
