Parallella Community • View topic - Question regarding the basic math example
Postby Reiner » Sun Jun 01, 2014 7:27 pm
Reiner
Re: Question regarding the basic math example
Postby Reiner » Tue Jun 03, 2014 5:49 pm
Reiner
Postby ysapir » Wed Jun 04, 2014 1:54 am
The section() attribute tells the linker to place the outbuf buffer in the Shared DRAM memory area. The location of Shared DRAM is defined in the linker file (*.ldf). If you use the sprintf() function, then I assume you use the legacy.ldf linker script. Have a look at the script with your editor, and you'll see how the section is defined.
ysapir
