Parallella Community • View topic - Heat: Infrared Thermal Testing
Postby federico » Sat Sep 07, 2013 4:25 pm
Hello Community,
I have an infrared camera on hand, so I thought I would put it to good use looking at where the heat is coming from.
These are images from a Gen-0 board. The general availability board (Gen-1) has significant improvements in power dissipation, so it will be nice to have a comparison here, it should be quite impressive a difference! So, if you don't have a board on hand, don't freak out - this is not the general availability board.
Without further ado - here it is.
There are two sets of images - the first, with the Parallela with no cooling whatsoever, the maximum temperature reached is around 200F around one of the power supply chips.
No fan - Gen-0 board
Parallella Gen-0 - no fan.jpg (39.43 KiB) Viewed 28821 times
Parallella Gen-0 - no fan (2).jpg (37.69 KiB) Viewed 28821 times
The entire board acts like a heat sink with the chip casing of the gen-0, so heat is spreading everywhere. To see where the power is coming from, we look at the board with the minimal cooling provided by a desk fan.
With fan - Gen-0 board
Parallella Gen-0 - with fan.jpg (32.38 KiB) Viewed 28821 times
With the fan, we can see that the power supply chips are clearly the worst offenders (they peak at 157F even cooled), while the Zync and Epiphany chips stay around a cool 115F, which is what we'd expect once the heat dissipation improvements are rolled out. There is not a lot of heat going into the board already, the issue is that it accumulates.
Just wanted to share the pictures, hope it helps. Rock on!
-Federico
federico
Re: Heat: Infrared Thermal Testing
Postby federico » Sat Sep 07, 2013 4:29 pm
One more shot with the fan on - showing the peak at the power supply chip.
Parallella Gen-0 - with fan (3).jpg (34.91 KiB) Viewed 28820 times
And the Epiphany
Parallella Gen-0 - with fan (4).jpg (35.5 KiB) Viewed 28820 times
federico
Postby tnt » Sat Sep 07, 2013 6:06 pm
Very nice shots !
Postby ysapir » Sat Sep 07, 2013 6:31 pm
Great post.
ysapir
Postby LamsonNguyen » Sat Sep 07, 2013 10:36 pm
Sweet.
LamsonNguyen
Postby aolofsson » Sun Sep 08, 2013 1:09 am
Postby federico » Sun Sep 08, 2013 4:09 am
federico
