Parallella Community • View topic - Technical Details Epiphany-V
Postby stefanluik » Tue Mar 14, 2017 9:25 am
could you tell some details about the chip ?
- Package size
- 16-bit external chip-addressing ?
- connection speed
Stefan
stefanluik
Re: Technical Details Epiphany-V
Postby olajep » Sat Apr 01, 2017 6:08 am
Reason: quote formatting
Postby dobkeratops » Sat Apr 01, 2017 9:57 am
what would a ballpark "IO Clock Cycle" be, I understand you may want to clock it at different rates
is the potential bandwidth the same for GPIO and inter-chip links
dobkeratops
Postby olajep » Sat Apr 01, 2017 11:31 am
Postby stefanluik » Mon Apr 03, 2017 9:29 am
thanks for replies,
I want just some secured infos:
- 1 billion processors are 1.000.000.000 processors. right ?
- what space is needed for the total chip ? what form factor (bga ...) is the total chip ?
- what will be the momentan thinking speed in GHz of the connection ports to neighbour chip ?
This infos are just for planning / designing a system like a supercomputer.
Thanks for
stefanluik
Postby sebraa » Mon Apr 03, 2017 10:58 am
I do not think you will get any secured infos. But I can speculate (since I am not with Adapteva and have never been). :-D
A billion according to the US is 1.000.000.000.
Epiphany G3 and G4 chips are only available in BGA, so I would assume the same for G5. If they will be available to the public at all.
Given the 1024 GPIO signals specified, you can infer a reasonable package size.
The interconnect clock rate will be limited by the same physics that any other system has to deal with.
Do not expect miracles, only good engineering.
