Parallella Community • View topic - Reference doc question
Re: Reference doc question
Postby sebraa » Tue Jan 24, 2017 4:27 pm
Are you following the original ABI (from the SDK documentation), the new ABI (with the new images), or do you have your own?
Postby upcFrost » Wed Jan 25, 2017 5:00 pm
upcFrost
Postby sebraa » Wed Jan 25, 2017 6:47 pm
For the new ABI, see and . Apart from that, good luck and my best wishes with your project. ;-)
Postby upcFrost » Thu Jan 26, 2017 10:15 am
upcFrost
Postby upcFrost » Wed Feb 22, 2017 3:54 pm
upcFrost
Postby jar » Thu Feb 23, 2017 6:38 am
Postby sebraa » Fri Feb 24, 2017 5:18 pm
All assembly instructions follow the scheme of "instruction destination, source". So it is "MOVTS config, r16" (because it copies from r16 to config) and "MOVFS r16, config" (because it copies from config to r16).
The switchable instruction set is one of the more annoying ISA decisions in the Epiphany, because it interacts badly with interrupts. If you require ISRs to never change (or always restore) the whole config register, you could skip the gid/gie dance in normal code.
Postby olajep » Fri Feb 24, 2017 6:36 pm
Postby upcFrost » Mon Mar 13, 2017 12:34 pm
upcFrost
