Parallella Community • View topic - Benefits of a serial cable, which to buy and how to use it.
Postby Gravis » Wed May 14, 2014 3:43 pm
USB serial monitor cable
Gravis
Re: Benefits of a serial cable, which to buy and how to use
Postby greytery » Wed May 14, 2014 4:30 pm
Thanks Gravis.
For those in the UK try :
@ £9.99. Handy if you are passing one of their shops.
or
@ £6.99
Inc. VAT, plus post.
I can confirm that it works with a Raspberry Pi, but will pay attention to the notes from Gravis when fitting to the Parallella.
There are a few tutorials on installation on Windows, including pointers to the necessary drivers, and connection to Pi. Most of these should transfer easilly.
Postby over9000 » Wed May 14, 2014 8:52 pm
over9000
Postby CIB » Thu May 15, 2014 5:19 am
Thanks, this will be useful for me, since I have no monitor to plug the parallela into.
CIB
Postby jaor » Fri Jul 04, 2014 8:23 pm
Hi, can you update your post with the following information (I'm a newbie, and was struggling a bit with it ;) ):
I am using PL2303HX based converter. As of this, I had to connect wires by myself, so there was no colors by default.
According to this post (viewtopic.php?f=10&t=845&start=20) you have to connect RX-TX and TX-RX and GND-GND.
Thanks for your post, it helped me a lot with debugging!
jaor
Postby daniel_dbb » Sat Sep 10, 2016 5:53 pm
I am using Adafruit FT232H Breakout board to communicate at TX/RX port with Parallella.
After Power ON I get:
U-Boot 2012.10-00003-g792c31c (Jan 03 2014 - 12:24:08) // <--- First Line
... (see more below)
Starting kernel ...
Uncompressing Linux... done, booting the kernel. // <--- Last Line
and after last line nothing more
No Promt for interaction with Parallella!
Why?
Does anybody expirienced same problem with Adafruit USB-UART Adapter?
Bye,
Daniel
I2C: ready
DRAM: 992 MiB
WARNING: Caches not enabled
MMC: SDHCI: 0
In: serial
Out: serial
Err: serial
Net: zynq_gem
Device: SDHCI
Manufacturer ID: 1b
OEM: 534d
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 59.6 GiB
Bus Width: 4-bit
reading parallella.bit.bin
2083744 bytes read
reading uImage
4468792 bytes read
reading devicetree.dtb
8607 bytes read
Image Name: Linux-3.12.0-g0bc9c3a-dirty
Data Size: 4468728 Bytes = 4.3 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Loading Device Tree to 1fffa000, end 1ffff19e ... OK
Starting kernel ...
daniel_dbb
Postby sebraa » Sun Sep 11, 2016 8:43 pm
By default, the serial console is disabled in new images.
Postby olajep » Mon Jan 09, 2017 3:33 pm
