Parallella Community • View topic - USB Camera
USB Camera
USB Camera
Postby zodane » Thu Aug 27, 2015 7:28 am
I have a project which consists of connecting a usb camera to my parallella then perform some tasks in programmable logic and some in ARM processor.
I'm using prallella 7020 with vivado
The first problem that i encounter is the connection between the soft and hard in another word how to send frames to PL.
I found this paper
which partition the ram in to Linux ram and DMA RAM and make use of several solution (open cv, Video4linux 2,...) to copy frame inti DMA RAM
but there is no source code no anything
Any idea how can i do this how to write in ram and then how to read
Would the DMA buffer sharing be a good solution for that?
In vivado design should i use AXI Video Direct Memory access?
Would the openCV work in the headless version (i dont need to see the video but to store it the SD card)
Regards
zodane
Re: USB Camera
Postby peteasa » Thu Aug 27, 2015 8:22 pm
I was thinking about the same thing. So to make things easier I created a complete environment with fpga development and linux kernel / linux software distribution. I added into the elink-redesign project the Analog Devices IP and now have a functioning system with hdmi, sound and elink-redesign (see branch elink-redesign at https://github.com/peteasa/parallella.git).
I have seen several things that could help whilst doing this project. First the Analog Devices IP libraries use a module axi_hdmi_tx_vdma that takes the video from the vdma and passes it to axi_hdmi_+tx_core to a control and data pipe line. It would be possible to intercept the video stream at that point. After this point the data is processed by the Analog Devices IP (for example color space coversion, RGB to CrYCb) and sent to the hdmi connection so it does not seem sensible to intercept beyond this point.
Easier might be to add a tap into the mm2s interface and do some processing on the vdma output then push it back into the axi_hdmi_tx unmodified via the mm2s interface. It would be possible to provide the stream of data to the epiphany chip and for the epiphany chip to do the processing and return the frames back to axi_hdmi_tx for delivery to hdmi. By using the "s" part of mm2s it would be possible to port this to future versions of Analog Devices IP more easily.
Another place to intercept the data is via the "normal" software route, ie packages like OpenCV bind the camera input to the video output (or file output) in software. I have loaded the v4linux drivers into my development environment but not yet OpenCV, so still at the planning stage at the moment. Not sure how easy it would be to offload some of the OpenCV processing onto the epiphany chip but at least OpenCV already has this type of interface built in.
Further it would be possible to intercept camera data (see for example Sylvain's work with the RiPi camera viewtopic.php?t=2514). However if you are like me and only have the USB camera its not obvious how to intercept the data from the USB port and anyway the format direct from the camera is likely to be YCbYCr so why not let the proven linux kernel drivers handle the various formats from the Camera.
I am still thinking about the best approach, the easiest would seem to be OpenCV..
peteasa
