Parallella Community • View topic - supercomputer.io
supercomputer.io
Re: supercomputer.io
Postby aolofsson » Tue May 26, 2015 5:33 pm
Postby jjg » Tue May 26, 2015 6:12 pm
Thanks for the info Andreas.
Sounds like there's not much to troubleshoot then. It's been a few hours and I still don't see my MAC address showing up on the website, so not sure what's left to debug with.
Too bad though, sounded like a clever project.
- Jason
jjg
Postby aolofsson » Tue May 26, 2015 6:18 pm
Jason,
If you PM or post your mac-id, then I will take a look at the resin.io internal system dasboard. There is some information there that is not visible on the web. There are a some boards that have failed to connect, so getting to the bottom of this will really help!
Postby aolofsson » Tue May 26, 2015 6:20 pm
btw. if there is anything really wrong with the image or sd card, you will be able to see it with the serial cable. The pre kernel messages from uboot do come up on the serial cable output.
Postby jjg » Tue May 26, 2015 6:33 pm
Here's the MAC: 04:4f:8b:00:27:17
I'll let you know what the serial console comes back with once I get things hooked up :)
- Jason
jjg
Postby kriegalex » Thu May 28, 2015 1:39 pm
Do some specific ports have to be opened for the parallella supercomputer image to work properly ? My school has a DMZ in which I can put the cards, but sysadmin needs to know which ports to open, by default only SSH is opened for remote server management.
Best regards
EDIT: I just saw that the card is available right now without even needing the DMZ network, well then I guess I won't bother giving it to the sysadmin :) Or maybe is the card available because it broadcasts regularly its presence (outgoing) but on the D day, the requests (the commands and data) will be blocked by the FW (ingoing) ? I don't know how exactly the system works with Docker and the VPN Manager (resin.io).
kriegalex
Postby proj964 » Thu May 28, 2015 7:10 pm
I have the same problem. It doesn't show up on supercomputer.io. (board has been powered up for hours now).
also i have a question, if you can't ssh into the parallella, then how do you shut it down without having microsd card corruption?
[edit] it occurs to me to also ask how you check the temperature of the two processor chips in this configuration?
[22:25cdt edit] it finally appeared on supercomputer.io.
proj964
Postby kriegalex » Fri May 29, 2015 7:24 am
For the temp, without SSH I guess it's impossible to check with the app xtemp, so the best is to stress test it with standard linux image and check temps are always OK via SSH, then use the resin.io image knowing temps are always ok, even when stressed.
kriegalex
Postby mmgc84 » Fri May 29, 2015 6:49 pm
Hi there I'm trying to connect my parallella to supercomputer.io but I think the kernel doesn't finish loading. Here is the log from serial connection > http://pastebin.com/DZvNhMgH
Regards
mmgc84
Postby rubyuser » Sun May 31, 2015 10:08 pm
I'm having the same problem.
My MAC 04:4f:8b:00:24:ab does not appear on http://supercomputer.io/#/devices, but it does appear for around 22 minutes in my router's active client list with a varying connection count, then it goes away. I can ping it while it appears in the client list, then it's unreachable.
The first time I burned the 7020 image to my Kickstarter board, it behaved the same way. I left it powered up for several days, and could never ping it again without cycling power, and it has never showed up on supercomputer/devices. Today I reburned the image, and confirmed the same behavior. Is there any logging that takes place to the SD card? (If not, why not?) What is the recommended way to connect to the serial port and capture the serial stream?
rubyuser
