Parallella Community • View topic - New Parallella SDK release! (Beta testers needed)
Postby aolofsson » Tue Nov 11, 2014 12:23 am
Hi all,
The new Epiphany SDK has finally been released!! We could need some brave testers for this new model before announcing release to 10,000 Parallella users and the rest of the world.
Major feature updates:
-An experimental software cache implementation
-A proper driver, so you no longer need to use "sudo"
-Multicore debugging from a single GDB client
-A new API for sharing symbols between Epiphany and ARM
-Includes an updated Linux kernel (needs the new driver).
Contributors:
Ben Chaco, Mikael Taveniku @ Xcube: Shared memory API, Sudo-less driver, Jenkins testing framework (e-hal)
Joern Roennecke, Simon Cook, Pierre Langlois @ Embecosm: Software caching (e-gcc)
Jeremy Bennett @ Embecosm: Multicore debugging (e-server, e-gdb)
Ola Jeppsson @ Adapteva: Integration and release of final SDK
Complete Release Notes:
https://github.com/adapteva/epiphany-sd ... 11-release
For testing, please grab the following ISO image and burn to a fresh sd-card using 'dd'. (it includes both partitions). Note that this will wipe out the complete SD card. A 4GB SD card will suffice.
7010 Devices: http://downloads.parallella.org/ubuntu/ ... 110.img.gz
7020 Devices: http://downloads.parallella.org/ubuntu/ ... 110.img.gz
Notes:
-The new SDK only works with the updated Linux kernel (uImage) due to the need for an Epiphany driver
-UART must be disabled in bootargs (still searching for root cause)
-GDB is not yet stable (unknown cause)
-Documentation still needs to be updated
-Currently only works in headless (likely configuration issue, still working on it)
Re: New Parallella SDK release! (Beta testers needed)
Postby AndyC » Tue Nov 11, 2014 9:22 pm
Nice one, I'm in.
I will give it a go tomorrow.
AndyC
Postby notzed » Wed Nov 12, 2014 3:04 am
Postby AndyC » Wed Nov 12, 2014 8:44 am
Trying to build toolchain on Ubunto 64 14.04:
andrewcapon@ubuntu:~/Parallella/sdk$ ./build-toolchain.sh --host arm-linux-gnueabihf
Logging to /home/andrewcapon/Parallella/logs/2014.11/build-2014-11-12-0837.log
START BUILD: Wed Nov 12 08:37:00 GMT 2014
Forcing clean build
Configuring build machine tool chain...
Building build machine tool chain...
ERROR: Tool chain build for build machine failed.
Build failed. See /home/andrewcapon/Parallella/logs/2014.11/build-2014-11-12-0837.log for details.
andrewcapon@ubuntu:~/Parallella/sdk$ tail -1000 /home/andrewcapon/Parallella/logs/2014.11/build-2014-11-12-0837.log | grep Error
checking iconv.h usability... make: *** [configure-libcpp] Error 1
What version of libcpp is required?
AndyC
Postby AndyC » Wed Nov 12, 2014 12:14 pm
AndyC
Postby AndyC » Wed Nov 12, 2014 12:53 pm
build.tar.gz
(476.23 KiB) Downloaded 1074 times
AndyC
Postby olajep » Wed Nov 12, 2014 6:39 pm
Postby AndyC » Wed Nov 12, 2014 7:08 pm
Hi Olajep,
Thanks very much for the pointers, I will give it a go......
I'm not sure if you work for Adapteva but I followed the instructions here https://github.com/adapteva/epiphany-sd ... 11-release which it sounds are not quite right! Maybe they should be updated?
Many thanks
Andy
AndyC
Postby AndyC » Wed Nov 12, 2014 7:51 pm
AndyC
Postby AndyC » Wed Nov 12, 2014 8:03 pm
AndyC
