Parallella Community • View topic - MicroSD boot speed
MicroSD boot speed
MicroSD boot speed
Postby doddy1985 » Tue Oct 08, 2013 4:41 pm
I just was curious if anyone would know:
If I were to buy a class 10 microSD card will this help boot up the OS quicker on start up (vs a class 6 or whatever)? Would it matter that much between classes? Is there a max data rate that the parallella board can handle, if so what is it?
Thanks!
doddy1985
Re: MicroSD boot speed
Postby malik123 » Sat Nov 02, 2013 7:14 am
malik123
Postby ysapir » Sat Nov 02, 2013 9:41 am
Various flash memory tests across the net show that more than a class, the specific type of card is more important.
Another issue is the reliability of these cards. Our experience is that not all cards are made equal (duh!). The first batch we used on the ZedBoard proved to be unreliable and many got corrupted after a few weeks of use.
You should consult online forums like Raspberry Pi's for a suggestion, as their user base is huge, with lots of experience.
ysapir
Postby over9000 » Sat Nov 02, 2013 1:27 pm
over9000
Postby doddy1985 » Sat Nov 02, 2013 1:33 pm
I will check raspberry pi. Thank you!
doddy1985
Postby hamster » Sat Nov 02, 2013 5:00 pm
A good resource for Raspberry Pi SD card speeds is http://elinux.org/RPi_SD_cards#SD_card_performance.
There seems to be three tiers of read performance - 4MB/s, 11MB/s and 19MBs.
Some cards are very weak (Kingston SDHC 32GB class 10 = 4.7MB/s) and others are very strong (SanDisk Ultra II SDHC 4GB class 4 (15 MB/s) = 20.9MB/s). I take that to indicate that some manufactures are stamping lower 'Class' ratings on higher spec cards rather than acutally manufacturing lower performing parts.
Mike
hamster
