Parallella Community • View topic - How to build a kernel on a Parallela board
Postby shodruk » Sat May 17, 2014 9:57 am
Re: How to build a kernel on a Parallela board
Postby shodruk » Tue May 20, 2014 7:20 am
Postby nickoppen » Sat May 24, 2014 11:03 am
Shodruky,
I'm having no luck with usb sound on my headset. I modified my .asoundrc to be the above file and I got "Cannot open default device" (or similar). Do I need to do anything else to use it?
I've got a Logitech head set connected to my hub and lsusb (which is now working!) shows it as device 5. I work mainly headless so I'd like to use my usb phones for sound.
Your HDMI version of this file works fine. I've gotten sound from vlc and SMPlayer.
I've tried alsaconf that most sites mention but that is not found. alsa-base is installed and up-to-date.
nick
nickoppen
Postby shodruk » Sat May 24, 2014 2:10 pm
nick,
What is the product name of your headset?
and post the outputs of these commands.
$ lsusb
$ cat /proc/asound/cards
$ cat /proc/asound/devices
$ cat /proc/asound/pcm
$ cat /proc/asound/timers
Postby nickoppen » Sun May 25, 2014 12:20 am
nickoppen
Postby shodruk » Sun May 25, 2014 7:59 am
What is the output of this command:
$ lsusb -v -d 046d:0a0c
reconnect the USB audio, then
$ tail -n 20 /var/log/syslog
Postby nickoppen » Sun May 25, 2014 8:16 am
headset.txt
Output from lsusb -v -d 046d:0a0c
(12.09 KiB) Downloaded 2356 times
nickoppen
Postby shodruk » Sun May 25, 2014 12:33 pm
Sorry, one more...
$ zcat /proc/config.gz | grep SND
Postby nickoppen » Sun May 25, 2014 9:19 pm
nickoppen
Postby shodruk » Mon May 26, 2014 10:41 am
It seems that your kernel doesn't support USB audio driver.
Are you using current kernel source and rebuilt it?
Also we have to enable USB audio driver with menuconfig.
# e.g. enable USB sound adapter
# Device Drivers->Sound card support->Advanced Linux Sound Architecture->USB sound devices->USB Audio/MIDI driver[*] (Press Y), Save, Exit
We should be able to see these options in a properly configured kernel.
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=y
viewtopic.php?f=48&t=1230#p7643
Return to Linux/U-Boot
