Parallella Community • View topic - Parallella Accessory Bundle (power connector)
Postby johan » Tue Aug 27, 2013 6:46 pm
Looking at the "Parallella Accessory Bundle" offered, I see no indication what power socket the adapter it is compatible with.
By looking at the accompanying picture I assume it only fits the North American 110V socket.
If the adapter is of the switching type and it can handle 230V then it could be made to fit using a socket adapter. But stacking adapter on adapter is not the most stable solution.
Please clarify the compatibility (on the order page), or offer an adapter with an interchangeable socket type (examples ).
johan
Re: Parallella Accessory Bundle (power connector)
Postby gceline » Tue Aug 27, 2013 9:45 pm
PSU is 5V 2A with a 'standard' 5.5mm OD, 2.1mm ID positive tip connector
It supports 110 - 240V AC, but has the US Pins. At this point we don't have any other options available, an adapter will be required
Graham
Adapteva
gceline
Postby Xythras » Fri Aug 30, 2013 4:32 pm
Hello, then the PSU could work in europe with only an adapter for pins?
Xythras
Postby 9600 » Fri Aug 30, 2013 5:46 pm
Postby nmalinoski » Tue Nov 26, 2013 2:40 pm
Getting an adapter for the included power supply isn't your only option. You can get one of these if you have your own 5V power supply, or you can apply 5V and ground directly to the appropriate mounting holes (You probably want to use metal standoffs for this).
Of course, if none of this really applies to you and you only have one board, a simple adapter as described above is probably best.
nmalinoski
