Parallella Community • View topic - Two Parallellas eLink cluster (interconnected)
Postby claudio4parallella » Wed Sep 13, 2017 9:18 am
claudio4parallella
Re: Two Parallellas eLink cluster (interconnected)
Postby jar » Wed Sep 13, 2017 1:37 pm
These are probably questions for Ola, directly.
Regarding #1, I can only suggest that it looks like the functionality was not needed in newer versions. Ola left comments to that effect:
https://github.com/adapteva/epiphany-li ... geLog#L561
Postby claudio4parallella » Wed Sep 13, 2017 8:11 pm
Thank you very much jar for your reply.
I'm realizing that my questions were badly asked.
1. it seems that the nnew release doesn't need any more that address initialization.
Could anybody confirm that this value has nothing to do with my attempt?
2. any suggestion about how to change 32 to 36 as needed for the two elink interconnected parallellas ?
peteasa and others have written many things here in the far past but I have not been so smart to understing every step or repeat these steps with the last image and sdk relase
thank for any help, my best
claudio4parallella
Postby olajep » Sat Sep 16, 2017 1:42 pm
Postby claudio4parallella » Sun Sep 17, 2017 10:30 am
claudio4parallella
Postby claudio4parallella » Sat Sep 23, 2017 6:56 am
It does work !
with esdk.2015.1
Now I'd like to port it to esdk.2016.1
claudio4parallella
Postby dejan » Fri Nov 10, 2017 5:52 pm
Where did you buy eLink (cables)?? I was looking for it everywhere! I have my old parallella kit (4 boards) and I would like to connect them using eLink, but have no idea where to buy the cables!??
dejan
Postby claudio4parallella » Sun Nov 12, 2017 8:30 pm
@dejan
Have a look at this post, I've explained my eLink cluster project starting from BillOfMaterial and links where to find all the items.
All according to an experience that was documented years ago using 2014 ParaUbuntu Image.
You could help me trying to port the cluster to last ParaUbuntu image 2017.11 .... will you?
Well, about cables you have two alternatives:
1 - purchase the Parallella eLink cables here already done (18 Pounds plus shipment)
2 - purchase >40 flat cable (of 1mm, not standard 1.27mm) and the 40 pin female plugs. It's easy to press the flat cable to grip the contacts
Let me know about your progress, keep us in touch!
claudio4parallella
Postby dejan » Mon Nov 13, 2017 2:57 pm
I do not have the porcupine board... :(
dejan
Postby claudio4parallella » Mon Nov 13, 2017 5:55 pm
without a Porcupine (http://www.digikey.com @ 35$), you need this DIY...
claudio4parallella
