Am trying to get Parallel board recognize my Wifi adapter (Edimax - RTL8188CUS). Rebuilt the kernel as per exact instructions given here. I have also built and installed the modules. The board boots successfully and gets IP (on ethernet); Can see it my router DHCP table and can ping as well. However, SSH/FTP returns port blocked.I am running the board headless and only way to get in is through SSH. So, have no access to logs or console as of now. SSH starts working when I bring back the old kernel. My guess is that it is something to do with permissions. Any help will be very much appreciated.
Update on 5/10:
Tried all possible options. Started fresh with headless image on a new SD card. Works fine with default kernel. Shuts me out completely as soon as I install the new kernel. I installed telnet to make sure the problem is not with ssh. Need help !! This is almost third day in row to make my Wi-fi work
Cheers
Sudhee
