Parallella Community • View topic - Been there, got the T-shirt
Postby ajtravis » Mon Nov 17, 2014 3:21 pm
I gave a talk at the Mario Negri Institute (non-profit pharma research) in Milan last week and promoted Parallella as a potential scale-out option for Bioinformatics work: "High Performance Computing for Bioinformatics: Scale up or scale out?"
I met people from the Mass Spectrometry lab at MNI after my talk and they are very interested in using Parallella as the controller and DSP computer for a low-cost DIY mass spectrometer project they have designed for use in schools/colleges for teaching. At present they are using a Raspberry Pi. I think Parallella is a better alternative but we need to get the USB working properly to gain credibility with potential users of Parallella as a 'Desktop' computer or instrument controller. USB is not an issue for the RPi, but it still is for a significant number of people (including me) who are using Parallella.
The DIY Mass Spectrometer requires 12-bit D/A to control the deflection field and 12-bit A/D to detect the molecular fragments. Is this the sort of thing that could be done using the Parallella FPGA directly (with a few passive componenents) or would it be better to use a GPIO board designed for the purpose? Bear in mind that this needs to be a low-cost project for schools/colleges.
Bye,
Tony.
2014-11-07 13.26.55.jpg (174.79 KiB) Viewed 8802 times
Re: Been there, got the T-shirt
Postby G4GUO » Mon Nov 17, 2014 10:16 pm
How you do it depends on the sample rate you require.
- Charles
G4GUO
Postby ajtravis » Tue Nov 18, 2014 9:38 am
Postby AndyC » Mon Nov 24, 2014 8:30 pm
You could do it using the FPGA but a 1khz/12 bit two channel sample rate could easily be handled without involving the FPGA at all you could just run the code on the arm using a low cost ADC using the GPIOs. I guess this is what they are doing with the Pi.
I have gone the other way with implementing a Sigma Delta DAC implemented on the FPGA, it might be interesting to have a go at the reverse way. Would you like me to have a look?
AndyC
Postby ajtravis » Tue Nov 25, 2014 9:52 am
