Firefox is always crashing
PostPosted: Mon Jan 26, 2015 2:18 pm
by Lou_Reed
On my Parallella, the Firefox application is always crashing. It then gives me the choice restarting Firefox or quitting Firefox. I choose to restart
However, Firefox should not crash so often. I have used in on other Linux builds on an Intel Xeon and it almost never crashes.
How do I fix this?
Any help appreciated. Thanks in advance.
Respectfully,
Lou_Reed
Re: Firefox is always crashing
PostPosted: Mon Jan 26, 2015 10:23 pm
by manklee
Firefox kept crashing on my Parallella until I set up some swap space.
PostPosted: Mon Feb 09, 2015 6:49 pm
by Lou_Reed
Okay, I created a swap file using the procedure that you can find here.
http://www.kevssite.com/2013/10/13/add- ... swap-file/
I followed the whole process, except the last step about modifying the
fstab file. I am not sure why I must do that. Anyway, it would not let me do anything to the
fstab file. What do I modify the fastab file for and are the instruction correct at the link above to do so?
Thanks in advance.
Respectfully,
Lou_Reed
PostPosted: Mon Feb 09, 2015 8:08 pm
by sebraa
If you run "swapon /swapfile", then the swap file is active.
If you add the line "/swapfile none swap defaults 0 0" to the end of your /etc/fstab, then the swap file will be activated on every boot.
PostPosted: Mon Feb 09, 2015 8:50 pm
by Lou_Reed
Thanks I will give it a try.
Respectfully,
Lou_Reed
PostPosted: Sun Mar 15, 2015 2:49 am
by BOBNINO
how do you add the line to /swapfile tho??
PostPosted: Wed Mar 18, 2015 2:05 pm
by Lou_Reed
Okay, I have created a swap file of size 512 MB. It seems to have ameliorated, but not solved the problem.
Firefox still crashes, but not as much. My guess is the swap file is doing its job, but it could stand to be a bit larger.
What is the ideal size of the swap file for the Parallella.
I am afraid that in answering this question the first sentence of any reply will say "it depends".
But be that as it may, what is an ideal swap file size?
Respectfully,
Lou_Reed
PostPosted: Wed Mar 18, 2015 4:33 pm
by adexmont
just for add my voice to this problem:
i created a swap partition (2GB) (need to activate manually every boot because fstab is not working /dev or id are the same)
get to firefox about:config and search for memory, set all the cache (and some voice that i think to understand to 0 but this didn't solve the problem.
don't know where to look elsewhere.
Edit: i'm using dillo that run fine, just a bit tricky to use but nice for simple reading action on hte web (like links)
PostPosted: Wed Mar 18, 2015 10:41 pm
by manklee
It depends! The other standard reply is 1x to 2x the amount of physical memory.
