Parallella Community • View topic - USB workaround
USB workaround
Re: USB workaround
Postby arhplanet » Mon Feb 23, 2015 8:12 pm
Hi everyone and thanks for a awesome little bord. I finally got the right ubuntu image installed and the usb works. Im however using the long cable trick. And I have spent countless hours in this forum to find a solution, and the one I found is to use the long cable.
But what i missed is why this happens? can anyone take the time to explain this properly in layman terms.
Cheers
Arne
arhplanet
Re: USB workaround
Postby Frida » Thu Jul 16, 2015 8:30 am
Congratulations, it's now a year since I found this error.
Is there really no one, with the right software that can fix this error?
I wish there was free software, so I could fix this myself!
Happy 1 year.
Frida
Re: USB workaround
Postby ajtravis » Thu Jul 16, 2015 9:08 am
Re: USB workaround
Postby tnt » Thu Jul 16, 2015 9:27 am
I'm still wondering why you even think the fix would be software ...
AFAICT everything points to a hardware issue. The design isn't at fault, it _should_ work according to the datasheet of the zynq and the ulpi phy. But sometimes it doesn't ... which could be due to either the ZYNQ or to the PHY not behaving. The workaround in this thread is to hold the phy reset line longer, but no amount of software can accomplish that because that line is just not controllable by software !
And speaking of USB issue, I'd like to point out the RPi has plenty of those too ! I use one has a console server to access USB serial console and it fails half the time (and yeah, it's using a powered hub, and an industrial 5V power supply so not a power issue). Even just doing a while true; do lsusb; done will inevitably end up in a crash.
Re: USB workaround
Postby tnt » Thu Jul 16, 2015 9:38 am
Re: USB workaround
Postby ajtravis » Thu Jul 16, 2015 10:05 am
Re: USB workaround
Postby tnt » Thu Jul 16, 2015 5:00 pm
Re: USB workaround
Postby ajtravis » Sun Jul 26, 2015 3:52 pm
Re: USB workaround
Postby ajtravis » Sat Aug 29, 2015 8:54 pm
Re: USB workaround
Postby Frida » Sun Jul 17, 2016 9:52 am
Congratulations 2 year and 1 day, and still no solution in sight.
Frida
