Parallella Community • View topic - Matmul-16 example gets stuck
Re: Matmul-16 example gets stuck
Postby miro » Thu May 15, 2014 12:14 pm
Hi Andreas,
sure, I'll be happy if this can get fixed that way :-) Somehow shipping it back from Germany and having trouble with custom office, and having to pay taxes again doesn't make me happy :-(
miro
Postby miro » Thu May 15, 2014 1:59 pm
I changed now to the headless bitstream and ran it now about 60 times without any error...
At least I'm happy so :-)
miro
Postby aolofsson » Thu May 15, 2014 5:23 pm
That is really good news! Looks like the issue on your board was solved by a new reset circuit implementation in the FPGA. The new FPGA bit stream includes a fix to the reset "errata item" found in E16G301 datasheet.
Postby cklin » Sat May 17, 2014 6:55 am
cklin
Postby AlbertoGP » Sun Jun 01, 2014 10:21 am
AlbertoGP
Postby zmc » Sun Jul 06, 2014 2:37 am
I'm having the matmul failing most of the time issue. I tried running epiphany-examples/archive/e-test, I had to copy test/common/src/test_common.c for the definition of e_write_ack to get it to compile, and it says BAD: CHIP FAILED!!!! all the time. This test looks old and unmaintained. Is there a more recent version of this I should run?
zmc
