This will help diagnose that.
The boot process is as follows
a) The board boots the Zynq uboot and searches for the FPGA image file on the SD card.
b) If it finds the parallella.bit.bin file on the BOOT partition of the SD card, then it continues with the boot and loads the uImage and devicetree files and then boots up the Ubuntu operating system on the /rootfs partition of the SD card.
c) Once the operating system begins to load, the drivers for the peripherals (Ethernet, HDMI, and USB) will load.
To find out if the board is booting, use a serial cable or try these steps below.
1) If the Image on the SD card is not good, then the board will not load the OS and the Ethernet, HDMI and USB will not operate (USB may get power, but this is not an indication of operation)
2) If the Ethernet is working, then it will activate DHCP and look for an IP Address – this is a good sign that the board has passed the boot phase and has started to load the OS.
3) Check your router’s DHCP allocation tables or use an IP Scanning tool to see if the board has an IP address.
Example of an IP Scanning tool: http://www.advanced-ip-scanner.com/
What it looks like when Parallella has not yet booted
- p1.png (80.7 KiB) Viewed 24154 times
What it looks like when Parallella has booted
- p2.png (74.3 KiB) Viewed 24154 times
If you are on a large network with many users, the Parallela can be identified by the MAC address which starts with 04:4F:8B:xx:xx:xx and is printed on the label on the board.
Now you have the IP address of the board, you should be able to ping the Parallella board at this address
Using a terminal emulation software like putty.exe or from a linux terminal you can also remotely access the board using SSH
- p3.png (59.2 KiB) Viewed 24154 times
Login using the username: linaro and password: linaro
- p4.png (50.51 KiB) Viewed 24154 times
If you get to this point, your system is working fine – you may have a cable or resolution issue with your HDMI or some other problem. Go to the forums for more help.
If you cannot ping or SSH into the board, it is probably not booting and the problem may be your SD card. Try re-imaging your SD card.
You can use a serial cable to access the board and see the boot messages and try and identify the problem. Instructions are available on the forums.
