Parallella Community • View topic - booting in a loop & "General error mounting filesystems.ss"
Postby stefan » Sun May 11, 2014 4:12 pm
I have finally been able to hook my board's serial connection up with my laptop, so I can inspect the (failing) boot sequence.
Here is a particularly interesting sequence of the output stream:
EXT4-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
Freeing init memory: 172K
General error mounting filesystems.ss (815) terminated with status 1
A maintenance shell will now be started.
CONTROL-D will terminate this shell and reboot the system.
Inconsistency detected by ld.so: dl-lookup.c: 876: _dl_setup_hash: Assertion `(bitmask_nwords & (bitmask_nwords - 1)) == 0' failed!
EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)nated with status 127
��33�3737�3s������~���n����������~���������;
The first thing to note is that, despite the note about a "maintenance shell", the board really reboots immediately (and thus I never get a chance to interfer, and the fs maximum mount count is reached etc.)
I also don't quite understand what the precise error is that triggers the boot process to abort in the first place. Is it the error just above, about "General error mounting filesystems.ss ..." ?
Any idea what I could do about it ? In fact, is there anything I can do (once I mount the filesystem directly from my laptop) to fix the boot process so it will give me the promised maintenance shell ?
Also, what is this error about the ld.so inconsistency detected by ld.so ?
Any help would be greatly appreciated,
stefan
Re: booting in a loop & "General error mounting filesystems.
Postby shodruk » Mon May 12, 2014 7:40 am
What SD card are you using? (brand, model, capacity...)
Try these command on a Ubuntu PC and post the outputs.
Set the SD card to your Ubuntu PC, then
sudo fdisk -l
Postby stefan » Mon May 12, 2014 11:47 am
It's a sandisk 16 GB disk. (fdisk -l reports:
Disk /dev/sdb: 14.9 GiB, 15931539456 bytes, 31116288 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x000a07b6
Device Boot Start End Blocks Id System
/dev/sdb1 63 96389 48163+ b W95 FAT32
/dev/sdb2 96390 15518789 7711200 83 Linux
stefan
Postby 9600 » Mon May 12, 2014 11:56 am
Postby stefan » Mon May 12, 2014 2:25 pm
The rootfs filesystem was indeed corrupted beyond repair, so I reinstalled it. Now booting works fine.
Thanks for your help !
stefan
