Parallella Community • View topic - Trying any epiphany test: board hangs
Postby Melkhior » Sun Nov 16, 2014 7:55 pm
I've just received my parallella (desktop) & micro-sd card. After a bit of
work, I managed to connect to the board via SSH, using the headless
kernel & bit.bin, and the custom DST without the UART (otherwise the
boot is not reliable). So far, so good :-)
However, no matter what I try in the epiphany-examples directory,
the board hang - all ssh sessions go dead, and the board doesn't
ping anymore. Power cycling brings it back to life. The big heatsink
only got warm-ish so far.
Power brick is rated @ 3A, so it should be more than enough.
<http://uk.rs-online.com/web/p/desktop-power-supply/7702801/>
Any idea what I should test?
Thanks in advance
Melkhior
Re: Trying any epiphany test: board hangs
Postby Melkhior » Mon Nov 17, 2014 7:12 am
I found the issue - I did not follow the instructions for the SD to the letter:
I did not rename the bit.bin file... so it was probably not loaded and there
would have been no interface with the epiphany.
It works now :-)
Melkhior
Postby xuewang » Wed Feb 22, 2017 2:26 am
Dear
I got the same problem with you, can you give me more clear explanation for me? What should I do to rename the bit.bin for using the interface of epiphany?
thank you
xuewang
Postby olajep » Wed Feb 22, 2017 8:14 pm
