Parallella Community • View topic - Headless + serial, hangs after booting
Postby oneelkruns » Fri Feb 27, 2015 10:54 pm
I'm trying to boot a micro-server Parallella board using this image:
ubuntu-14.04-headless-z7010-20150130.1.img
with a serial cable connected. The boot starts with this output:
I2C: ready
DRAM: 992 MiB
WARNING: Caches not enabled
MMC: SDHCI: 0
In: serial
Out: serial
Err: serial
Net: zynq_gem
Device: SDHCI
Manufacturer ID: 27
OEM: 5048
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading parallella.bit.bin
2083744 bytes read
reading uImage
3391040 bytes read
reading devicetree.dtb
7447 bytes read
Image Name: Linux-3.14.12-parallella-xilinx-
Data Size: 3390976 Bytes = 3.2 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Loading Device Tree to 1fffb000, end 1ffffd16 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 3.14.12-parallella-xilinx-g40a90c3 (esim@adapteva-dev) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu5
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Parallella Gen1
bootconsole [earlycon0] enabled
cma: CMA: reserved 128 MiB at 27800000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @e6fe0000 s9024 r8192 d15552 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 252432
Kernel command line: root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 868820K/1015808K available (4609K kernel code, 217K rwdata, 1544K rodata, 176K init, 209K bss, 146988K reserv)
Virtual kernel memory layout:
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
.text : 0xc0008000 - 0xc060a7f8 (6154 kB)
.init : 0xc060b000 - 0xc0637340 ( 177 kB)
.data : 0xc0638000 - 0xc066e5e0 ( 218 kB)
.bss : 0xc066e5ec - 0xc06a29f4 ( 210 kB)
Preemptible hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
slcr mapped to f0004000
zynq_clock_init: clkc starts at f0004100
Zynq clock init
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 1207951633ns
timer #0 at f0006000, irq=43
Console: colour dummy device 80x30
console [tty0] enabled
bootconsole [earlycon0] disabled
And hangs after that. Is there no serial console? If not, how can it be enabled?
Thanks!
Ron
oneelkruns
Re: Headless + serial, hangs after booting
Postby rrroger » Wed Apr 08, 2015 3:18 am
I'm a newer in Parallella board, met the same problem.
I tried some SD card images in both tutorial and ftp, the following image can work correctly.
ftp://ftp.parallella.org/sd_images/ubun ... 6g1.img.gz
If you want a quick start, I think it's a good choice.
Then I'm trying to generate a new image to solve this issue.
Runbin
rrroger
Postby ArunD » Tue Jun 02, 2015 6:26 pm
ArunD
Postby ArunD » Wed Jun 03, 2015 8:29 am
ArunD
