cifs
Posted:
Fri Oct 24, 2014 10:40 pm
by steve.j.wilcox
I am trying to access data held on a samba share using the cifs-utils package. I can see the share using smbclient, however, although I can install the package it appears that the kernel does not support the filesystem, is this correct, and is there any way to access the share?
Re: cifs
Posted:
Sun Oct 26, 2014 1:37 pm
by 9600
It looks as though you may need a kernel with CONFIG_CIFS and this is not enabled by . If that is the case, you will need to build your own kernel, or alternatively you may be able to use a userspace implementation such as fusesmb.
Re: cifs
Posted:
Mon Oct 27, 2014 10:27 pm
by steve.j.wilcox
Many thanks, I'll give fuse a go first
