Parallella Community • View topic - ARM NEON question
ARM NEON question
ARM NEON question
Postby over9000 » Tue Oct 29, 2013 2:04 pm
I've been reading about this and one thing is puzzling me: does each CPU core have its own NEON unit, or is it shared between all CPU cores? The docs I've looked at refer to it as the "NEON unit", and it's physically in a separate location to the CPU cores on chip. If it is just a single unit, then what's the normal procedure for allowing multi-threaded/multi-core programs to share access to it? Unfortunately, I wasn't able to find an answer to either of these questions on the web, so I thought that maybe someone here would know. Thanks.
over9000
Re: ARM NEON question
Postby Gravis » Tue Oct 29, 2013 7:35 pm
Gravis
Postby over9000 » Wed Oct 30, 2013 2:18 pm
over9000
Return to Assembly
