Parallella Community • View topic - FPGA download method
Postby Gilvin » Thu Jul 25, 2013 8:47 am
Hi folks, I'm a beginner with FPGA and I've studied this page:
http://www.adapteva.com/white-papers/bu ... -platform/
I'm not sure how to download the FPGA bit-stream into the chip, do I need to buy an additional Xilinx FPGA downloader? Or I could just put my bit-stream file into the SD card and let ARM do the work for me?
Sorry if the question is too stupid :mrgreen:
Gilvin
Re: FPGA download method
Postby 9600 » Thu Jul 25, 2013 9:23 am
Postby aolofsson » Thu Jul 25, 2013 1:42 pm
The method that Andrew mentioned was the initial one used for the Zedboard based prototype. The actual Parallella board has the FPGA bitstream as a separate file in the BOOT partition of the SD card. You can update the bitstream by just placing a new file in that partition. The file should be called "parallella.bit.bin."
Postby Gilvin » Thu Jul 25, 2013 4:36 pm
Thanks all, got the idea :D
Gilvin
Postby wuher » Fri Jul 26, 2013 8:50 am
Now that I think about this - does Parallella have a JTAG header somewhere?
wuher
Postby aolofsson » Fri Jul 26, 2013 2:16 pm
The JTAG pins go through the PEC_POWER connector. There will be a breakout board to provide easy access to these pins. There will likely not be a jtag header, so you will need to use the "patch wire cable" to hook up to the 0.1in header on the breakout board.
Postby Sundance » Sat Jul 27, 2013 4:32 pm
1. The Xilinx JTAG interface is described here - http://www.xilinx.com/products/boards-a ... B-II-G.htm - and is a USD225.00 investment - and NO, I do not work for Xilinx ;) Alternatives are available or a second-hand from eBay. Useful for download/debug of FPGA, but the bit-streams can be integrated in the boot-file, so not sure that really required for Parallella Users.
No user for Epiphany programming/debug. :geek:
2. Multiple ideas are floating around for a "Break-Out" board to hold the Parallella. One idea is here - viewtopic.php?f=11&t=406&start=10 - and the JTAG are available on the 0.1" Headers and could be daisy-chained. The Xilinx unit ships with 0.1" cables.
This - P0002 - is still a "Work-in-Progress", and the JTAG lines could be routed to a separate 14-way header, as found on the Xilinx Cable, if that is a chosen route by the Community.
Flemming Christensen
Mobile: +44 7 850 911 417;
Skype: Flemming_Sundance
Company Home Page:
Sundance
Users browsing this forum: No registered users and 105 guests
