What connector goes to PEC_Power?
I bought the Parallella board, and wanted to learn about how to interact with a JTAG (so I bought the kit and the cables). After looking through the Parallella manual it says the connectors for the JTAG are on the PEC_POWER connector on the bottom side of the board. But when I look at that connector it has tiny connection points, and lots of them. I am assuming there is some kind of additional connector I have to buy in order to get access to these JTAG pins on the PEC_POWER connector. If this is true then what kind of connector do I need to buy to interact with the pins described in the manual on the PEC_POWER?
Thank you for any help and advice you are able to provide.
-Matt
-Matt
