Parallella Community • View topic - Is the FPGA programming accessible?
PostPosted: Tue Jun 24, 2014 9:07 am
by webmasterpdx
Is the FPGA Verilog available for adding custom functionality? Did the designers use Verilog or VHDL?
Is this a planned function or would I have to modify the original Verilog to do this?
If accessible, how many LUTs are available for our use?
I'm interested in things like adding a butterfly address generator for FFT bit and digit reverse. Also could add tweak value tables and Cosine lookup tables to speed up FFT algorithms. These addresses could be generated and added to memory accessing addresses controling the addressing of data that gets sent in to the Epiphany chip for the actual calculations. I'm not yet familiar with the system and the epihpany architecture yet as this may not be necessary if that functionality is already possible from the Epiphany cores.
In general fast cosine lookup tables have their uses too. I can think of many other applications that having spare LUTs around could be very useful.
Thank you in advance.
Re: Is the FPGA programming accessible?
PostPosted: Tue Jun 24, 2014 9:51 am
by AlbertoGP
There are some figures about the FPGA utilization in the thread
The FPGA sources are in the hardware repo:
You can find all the repos from using the Sources menu at the top.
PostPosted: Tue Jun 24, 2014 10:30 am
by webmasterpdx
Thank you. That resource list is interesting. Sounds like there is a bunch of space available, especially if I get a board with the 7020 on it. Will the 64 node board come with the 7020????
That will be a hell of a fun board to play with.
The only way that could be better would be if they could fit it on a USB-stick :-)
PostPosted: Tue Jun 24, 2014 11:39 am
by timpart
