7010 FPGA design files
Re: 7010 FPGA design files
Postby theover » Thu Jun 19, 2014 4:34 pm
Today, I went through the motions on the HDMI build for my 7010 board, first I got a "no license" from xmp, which somehow apparenly doesn't matter. When I loaded the main project, first it started some ((I suppose one time only) netlist creation I suppose from the hdmi interface, because I didn't get that from the non-hdmi build, which lasted 7 minutes.
The I pressed go on the ISE for creating the with-hdmi bitfile, and 5 minutes later, there is was, and it tested ok. No wonder, because it is bit-for-bit the same as the supplied bit file, probably created with the same ISE version I had prepared towork with months ago.
T.
