Parallella Community • View topic - Power Supply
Power Supply
Re: Power Supply
Postby gceline » Fri Jul 11, 2014 7:33 pm
This looks like it meets the specs, but our experience has shown that the cheaper the product the less likely it is to perform to spec - you may be better off using a supply from a reliable vendor.
http://www.digikey.com/product-detail/e ... ND/2235250
Graham
Adapteva
gceline
Re: Power Supply
Postby Janos » Sat Jul 12, 2014 10:08 am
I would like the option of buying a board without a power supply.
Janos
Re: Power Supply
Postby jubertroldan » Sun Nov 30, 2014 11:08 am
I have the default 5VDC and 3A 15Watts power adaptor that came in with the board, can I use it to supply two (2) parallella boards? connecting them in parallel?
kind regards,
Jubert
jubertroldan
Re: Power Supply
Postby 9600 » Sun Nov 30, 2014 6:07 pm
That would probably work fine when both boards are idle else running light workloads, but I wouldn't recommend it, since one of the most common causes of problems is insufficiently rated power supplies.
