Can I power 2 Parallella boards using the adaptor provided?
I bought 2 7020 Parallella boards with complete set of accessories previously ( back May 25,2014). I would like to know if it would be possible to run 2 parallella boards using a single power adaptor? as the ratings says below:
Model: ADS6818-1505-WD
Input: 100-240VAC, 50/60Hz, 0.5A
Output: 5VDC 3A 15W
I believe the Parallella draws/runs on 5Watts each therefore the power supply could be potentially tap the other board in Parallel connection? anybody got any idea if this would work?
Thank you so much for your help!
kind regards
Jubert
Output: 5VDC 3A 15W
- Power Adaptor
- poweradaptor.jpg (650.72 KiB) Viewed 10678 times
kind regards
Jubert
