Parallella Community • View topic - Parallella Cluster Kit - eLink Cables
Re: Parallella Cluster Kit - eLink Cables
Postby greytery » Tue May 27, 2014 10:18 am
And I would like another one (literally).
May/may not be related/off -topic, but if the cable connects two boards, then wouldn't one (or both) of the boards also need an addressing daughter board to set its coordinates?
Otherwise (AFAICT) the eMesh addressing won't work. Multiple board cluster - different coordinates.
If so, then it implies that we might need a cabling kit - rather than just the cable.
Postby aolofsson » Tue May 27, 2014 10:44 am
Connecting boards with eLink cables is still work in progress..but here is the current status.
https://twitter.com/adapteva/status/471220992178520064
Postby greytery » Tue May 27, 2014 11:29 am
The beasts exist! - the connectors, I mean.
That tweet shows the PEC_FPGA's connected - but it's not something that can be repeated in a stack. Maybe it's all I need (for two boards).
For stacked clusters with eMesh connection, the PEC_NORTH -> PEC_SOUTH eLink cable(s) need to bend across the board(s). I'm not sure what that does for the heat dissipation but it won't do either the cable or the Epiphany any good.
Probably need different, slightly longer cables and clearance for any heatsink(s).
Good luck.
Postby timpart » Tue May 27, 2014 11:32 am
Postby aolofsson » Tue May 27, 2014 11:41 am
Yes...these are straight through cables, which means it will not be possible to connect the North to the South link directly with these cables. In the future, we would prefer working with some kind of backplane. Most experienced system designers would agree that custom cabling is a mess...
Notes:
-The cables should work quite will for connecting two Parallella boards together through the PEC_FPGA.
-They will also be useful for connecting the Parallella to future expansion boards.
-The cables are quite stiff so using them for connecting stacks of boards will not work.
-It should be possible to connect the PEC_FPGA to the PEC_NORTH/PEC_SOUTH if you lay out the cards on a table. (not tested yet as we haven't had time yet to instantiate the eLink on the PEC_FPGA interface)
Postby timpart » Tue May 27, 2014 1:22 pm
Postby dejan » Mon Jun 16, 2014 3:40 pm
Same here... I really need eLink cables to connect my Parallella boards the way I want...
dejan
Postby hmiranda » Sat Mar 28, 2015 9:42 pm
Hi, someone knows from what store I am able so get this cables to connect two desktop boards ? thanks in advance.
Best regards,
Horacio Miranda
hmiranda
