Parallella Community • View topic - Cross compile - Nice simple build?
Postby AndyC » Thu Aug 07, 2014 8:31 am
AndyC
Re: Cross compile - Nice simple build?
Postby notzed » Thu Aug 07, 2014 10:11 am
Postby AndyC » Thu Aug 07, 2014 10:40 am
Hi, Thanks for the reply:
linaro-nano:~> file cccompiled
cccompiled: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.16, not stripped
linaro-nano:~> ldd cccompiled
not a dynamic executable
So ldd seems to have problems with it, any ideas?
Andy
AndyC
Postby notzed » Fri Aug 08, 2014 5:58 am
you need to run ldd on the target machine
Postby AndyC » Fri Aug 08, 2014 6:13 am
That was running on the target machine.
Cheers
Andy
AndyC
Postby notzed » Fri Aug 08, 2014 11:22 am
ahh sorry, didn't see the prompt. well i'm out of ideas!
Postby AndyC » Fri Aug 08, 2014 11:32 am
What version of the esdk are you using on linux?
AndyC
Postby AndyC » Fri Aug 08, 2014 1:56 pm
I fixed the issue by installing gcc-arm-linux-gnueabihf and not using the code chain they supply with the sdk!
AndyC
Users browsing this forum: No registered users and 68 guests
