Parallella Community • View topic - cannot boot
cannot boot
cannot boot
Postby stefan » Thu Mar 27, 2014 11:58 pm
I finally got my board and required cabling together to start playing. After powering up the board I eventually see two little penguins in the upper left corner of the screen, but nothing else. I assume the boot process got stuck somewhere, but I have no idea where, or why. Unfortunately I haven't yet got a serial connection set up, so I can't watch the log of the boot process.
Any idea what might go wrong ? (I have connected a monitor, as well as an externally powered USB hub, though nothing plugged in yet. I can mount the two sdcard partitions on my laptop, and both look valid.)
Many thanks,
Stefan
stefan
Re: cannot boot
Postby Janos » Fri Mar 28, 2014 6:39 am
Can you get remote access via ssh or can you open a terminal window?
As you can mount the card in your laptop can you check the boot logs and see if there is anything going wrong?
Janos
Re: cannot boot
Postby aolofsson » Fri Mar 28, 2014 11:33 am
Stefan,
We have seen the penguins get stuck once in a while. The solution has been to push the reset button on the board and go again. So far, it seems that it's related to noise on the serial port. We do not see this issue with the serial port plugged in. We are working on a kernel fix.
Re: cannot boot
Postby stefan » Fri Mar 28, 2014 11:41 am
Janos,
I couldn't access the board remotely, i.e. the board didn't show up in my router yet. Trying to look at the logs after mounting the sdcard on my laptop is a good idea, I'll do that.
Andreas,
thanks for confirming the symptoms are known. I'll hit the reset button a couple of more times and hope.
Meanwhile I have ordered a USB-UART adapter, so plugging that in my help (either by reducing the noise or at least to let me see where things get stuck).
Many thanks for the replies,
Stefan
stefan
Re: cannot boot
Postby shawnallen » Wed Apr 02, 2014 10:00 pm
Is there a time frame for this to be implemented?
My two devices rarely ever boot (Out of at least 50 tries, they've come up twice) and I think this is why, and I shouldn't need to buy more cables to get this up and running.
shawnallen
Re: cannot boot
Postby timpart » Fri May 09, 2014 4:44 pm
If this hasn't been fixed yet in the kernel, would connecting a patch wire between Rx and Gnd (next to Ethernet connector) stabilize the UART?
Re: cannot boot
Postby stefan » Fri May 09, 2014 5:07 pm
I would very much appreciate some tips for workarounds for this until this is properly fixed. I still haven't managed to boot my board yet. :-(
Stefan
stefan
Re: cannot boot
Postby FHuettig » Fri May 09, 2014 6:40 pm
Re: cannot boot
Postby Hybridalienrob » Sat May 10, 2014 1:56 pm
I too have the same problem, I get two penguins and that's it. Not sure if the dhcp has assigned an IP address and I've tried ssh'ing into the IPs listed on my router without any success.
I don't have a usb/serial dongle yet as it's still in the post so can't connect or check the serial output and I'm a bit reluctant to start shorting pins on my brand new parallella.
Here's the dmesg log file I extracted by putting the card into my PC. Do those failures at the end look normal ?
Booting Linux on physical CPU 0x0
Linux version 3.12.0-g0bc9c3a-dirty (karol@karol) (gcc version 4.5.2 (Sourcery G++ Lite 2011.03-42) ) #6 SMP PREEMPT Wed Jan 29 10:25:25 CET 2014
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZED
bootconsole [earlycon0] enabled
cma: CMA: reserved 40 MiB at 2d000000
Memory policy: Data cache writealloc
On node 0 totalpages: 253952
free_area_init_node: node 0, pgdat c09046c0, node_mem_map c0e35000
Normal zone: 1520 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 194560 pages, LIFO batch:31
HighMem zone: 464 pages used for memmap
HighMem zone: 59392 pages, LIFO batch:15
PERCPU: Embedded 8 pages/cpu @c1607000 s9024 r8192 d15552 u32768
pcpu-alloc: s9024 r8192 d15552 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 252432
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait devtmpfs.mount=0
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 951304K/1015808K available (6201K kernel code, 374K rwdata, 2436K rodata, 188K init, 5307K bss, 64504K reserved, 237568K highmem)
Virtual kernel memory layout:
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
.text : 0xc0008000 - 0xc08777d8 (8638 kB)
.init : 0xc0878000 - 0xc08a7340 ( 189 kB)
.data : 0xc08a8000 - 0xc0905be0 ( 375 kB)
.bss : 0xc0905bec - 0xc0e34a08 (5308 kB)
Preemptible hierarchical RCU implementation.
RCU lockdep checking is enabled.
Dump stacks of tasks blocking RCU-preempt GP.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:16 nr_irqs:16 16
slcr mapped to f0004000
Zynq clock init
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 1207ms
timer #0 at f0006000, irq=43
Console: colour dummy device 80x30
Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
... MAX_LOCKDEP_SUBCLASSES: 8
... MAX_LOCK_DEPTH: 48
... MAX_LOCKDEP_KEYS: 8191
... CLASSHASH_SIZE: 4096
... MAX_LOCKDEP_ENTRIES: 16384
... MAX_LOCKDEP_CHAINS: 32768
... CHAINHASH_SIZE: 16384
memory used by lock dependency info: 3695 kB
per task-struct memory footprint: 1152 bytes
Calibrating delay loop... 1325.46 BogoMIPS (lpj=6627328)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0xc05e08a0 - 0xc05e08d4
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 512 kB
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated.
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
zynq_gpio e000a000.gpio: gpio at 0xe000a000 mapped to 0xf0010000
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
bio: create slab <bio-0> at 0
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Initialized.
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource ttc_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 6, 294912 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 3, 40960 bytes)
UDP-Lite hash table entries: 512 (order: 3, 40960 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
bounce pool size: 64 pages
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
msgmni has been set to 1474
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-2364208
dma-pl330 f8003000.ps7-dma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0001000.uart: ttyPS0 at MMIO 0xe0001000 (irq = 82, base_baud = 3124999) is a xuartps
console [ttyPS0] enabled, bootconsole disabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f0016000
[drm] Initialized drm 1.1.0 20060810
platform 6c000000.axi_hdmi: Driver axi-hdmi requests probe deferral
brd: module loaded
loop: module loaded
xqspips e000d000.qspi: master is unqueued, this is deprecated
m25p80 spi32766.0: found n25q128a13, expected m25p80
m25p80 spi32766.0: n25q128a13 (16384 Kbytes)
5 ofpart partitions found on MTD device spi32766.0
Creating 5 MTD partitions on "spi32766.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000540000 : "config"
0x000000540000-0x000000fc0000 : "image"
0x000000fc0000-0x000001000000 : "spare"
xqspips e000d000.qspi: at 0xE000D000 mapped to 0xF0018000, irq=51
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54
usbcore: registered new interface driver rtl8192cu
usbcore: registered new interface driver zd1201
aoe: AoE v85 initialised.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
xi2cps e0004000.i2c: 100 kHz mmio e0004000 irq 57
usbcore: registered new interface driver zr364xx
usbcore: registered new interface driver stkwebcam
usbcore: registered new interface driver s2255
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
usbcore: registered new interface driver benq
usbcore: registered new interface driver conex
usbcore: registered new interface driver cpia1
usbcore: registered new interface driver etoms
usbcore: registered new interface driver finepix
usbcore: registered new interface driver jeilinj
usbcore: registered new interface driver jl2005bcd
usbcore: registered new interface driver kinect
usbcore: registered new interface driver konica
usbcore: registered new interface driver mars
usbcore: registered new interface driver mr97310a
usbcore: registered new interface driver nw80x
usbcore: registered new interface driver ov519
usbcore: registered new interface driver ov534
usbcore: registered new interface driver ov534_9
usbcore: registered new interface driver pac207
usbcore: registered new interface driver gspca_pac7302
usbcore: registered new interface driver pac7311
usbcore: registered new interface driver se401
usbcore: registered new interface driver sn9c2028
usbcore: registered new interface driver gspca_sn9c20x
usbcore: registered new interface driver sonixb
usbcore: registered new interface driver sonixj
usbcore: registered new interface driver spca500
usbcore: registered new interface driver spca501
usbcore: registered new interface driver spca505
usbcore: registered new interface driver spca506
usbcore: registered new interface driver spca508
usbcore: registered new interface driver spca561
usbcore: registered new interface driver spca1528
usbcore: registered new interface driver sq905
usbcore: registered new interface driver sq905c
usbcore: registered new interface driver sq930x
usbcore: registered new interface driver sunplus
usbcore: registered new interface driver stk014
usbcore: registered new interface driver stk1135
usbcore: registered new interface driver stv0680
usbcore: registered new interface driver t613
usbcore: registered new interface driver gspca_topro
usbcore: registered new interface driver tv8532
usbcore: registered new interface driver vc032x
usbcore: registered new interface driver vicam
usbcore: registered new interface driver xirlink-cit
usbcore: registered new interface driver gspca_zc3xx
usbcore: registered new interface driver ALi m5602
usbcore: registered new interface driver STV06xx
usbcore: registered new interface driver gspca_gl860
usbcore: registered new interface driver Philips webcam
cpia2: V4L-Driver for Vision CPiA2 based cameras v3.0.1
usbcore: registered new interface driver cpia2
usbcore: registered new interface driver sn9c102
usbcore: registered new interface driver em28xx
Em28xx: Initialized (Em28xx Audio Extension) extension
usbcore: registered new interface driver usbtv
zynq_wdt f8005000.swdt: Xilinx Watchdog Timer at f0032000 with timeout 10s
usb 1-1: new high-speed USB device number 2 using xusbps-ehci
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: Invalid maximum block size, assuming 512 bytes
mmc0: SDHCI controller on e0101000.sdhci [e0101000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ashmem: initialized
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SU16G 14.8 GiB
logger: created 256K log 'log_system'
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
mmcblk0: p1 p2
adv7511-hdmi-snd adv7511_hdmi_snd.4: adv7511 <-> 75c00000.axi-spdif-tx mapping ok
TCP: cubic registered
NET: Registered protocol family 17
Registering SWP/SWPB emulation handler
Console: switching to colour frame buffer device 240x75
usb 1-1.2: new low-speed USB device number 3 using xusbps-ehci
axi-hdmi 6c000000.axi_hdmi: fb0: frame buffer device
axi-hdmi 6c000000.axi_hdmi: registered panic notifier
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 on minor 0
ALSA device list:
#0: HDMI monitor
input: NOVATEK USB Keyboard as /devices/amba.1/e0002000.usb/xusbps-ehci.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
hid-generic 0003:0461:0010.0001: input,hidraw0: USB HID v1.10 Keyboard [NOVATEK USB Keyboard] on usb-xusbps-ehci.0-1.2/input0
input: NOVATEK USB Keyboard as /devices/amba.1/e0002000.usb/xusbps-ehci.0/usb1/1-1/1-1.2/1-1.2:1.1/input/input1
hid-generic 0003:0461:0010.0002: input,hidraw1: USB HID v1.10 Device [NOVATEK USB Keyboard] on usb-xusbps-ehci.0-1.2/input1
usb 1-1.4: new low-speed USB device number 4 using xusbps-ehci
input: Logitech Optical USB Mouse as /devices/amba.1/e0002000.usb/xusbps-ehci.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input2
hid-generic 0003:046D:C016.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-xusbps-ehci.0-1.4/input0
EXT4-fs (mmcblk0p2): recovery complete
Freeing unused kernel memory: 188K (c0878000 - c08a7000)
systemd-udevd[1029]: starting version 204
init: systemd-logind pre-start process (1148) terminated with status 32
systemd-udevd[1062]: could not open moddep file '/lib/modules/3.12.0-g0bc9c3a-dirty/modules.dep.bin'
init: bluetooth main process (1193) terminated with status 1
init: bluetooth main process ended, respawning
init: plymouth main process (943) killed by ABRT signal
init: avahi-cups-reload main process (1435) terminated with status 1
init: plymouth-splash main process (1443) terminated with status 2
init: bluetooth main process (1439) terminated with status 1
init: bluetooth main process (1488) terminated with status 1
init: bluetooth main process (1527) terminated with status 1
init: failsafe main process (1549) killed by TERM signal
init: bluetooth main process (1606) terminated with status 1
init: bluetooth main process (1659) terminated with status 1
init: bluetooth main process (1713) terminated with status 1
systemd-logind[1753]: New seat seat0.
systemd-logind[1753]: Failed to save seat data for seat0: No such file or directory
init: plymouth-stop pre-start process (1777) terminated with status 1
Hybridalienrob
Re: cannot boot
Postby Hybridalienrob » Sat May 10, 2014 9:27 pm
In my cast at least it looks like a bad SD image was the problem. I followed the 'flexible' method described but if I program the pre-prepared image it seems to boot into the GUI athough I have no mouse or keyboard yet... next thing to resolve.
Hybridalienrob
Users browsing this forum: No registered users and 82 guests
