Parallella Community • View topic - cooling and more memory?
Re: cooling and more memory?
Postby Calle » Sun Mar 16, 2014 5:54 pm
Calle
Postby aolofsson » Sun Mar 16, 2014 7:27 pm
The placement of the tall cap was unfortunate...we are now testing to see if it's safe to remove it. So far so good...
In the future versions, these tall 100uF caps will be moved to to the bottom side.
Postby Janos » Sun Mar 16, 2014 7:58 pm
Very nice
Janos
Postby Calle » Mon Mar 24, 2014 9:37 pm
Anyone running something like a 120mm computer fan on a couple of Parallellas? How do you power it?
Calle
Postby ubii » Mon Mar 24, 2014 10:08 pm
Calle,
If you can find a 5V fan, then you can draw power from the board itself, as explained in the following post.
viewtopic.php?t=1049&p=6643#p6643
The other option is to use a standard PC power supply and use the 5V rail to power the board(s) and the 12V rail to power the fan(s).
ubii
Postby Calle » Tue Mar 25, 2014 7:13 pm
Calle
Postby ubii » Tue Mar 25, 2014 8:52 pm
Calle,
No problem, happy to help any way I can. As for using a PC PSU, I actually got the idea from several RPi Clusters that I have seen built, like in the video below.
https://www.youtube.com/watch?v=i_r3z1jYHAc
Seeing as I only have the initial Zedboard-based prototype and a Gen 1.1 Parallella board, as part of the EARLY-ACCESS pledge level, I really don't have much of a need yet for a PC PSU to power everything. Originally, I had planned on buying either a mini-cluster (4 boards) or cluster (8 boards), but upgraded my pledge shortly before the end of the KS campaign. Once they start accepting new orders, I will probably order at least a few more boards and build a small cluster.
As for powering a cluster of Parallella boards using a PC PSU, you could either connect the 5V rail to the mounting hole pads, like 9600 suggested, and power all the boards by connecting together with metal standoffs or build/buy several molex to barrel plug adapters and only power the boards via the barrel jacks.
ubii
Postby Transcendental » Tue May 06, 2014 7:59 pm
At J15, to power a fan, is there any particular reason a U-shaped wire is recommended for soldering, instead of a pair of header pins and jumper ?
Transcendental
Postby aolofsson » Tue May 06, 2014 8:05 pm
Yes, due to a "doh!" in layout, the J15 was placed directly above the samtec connector on the bottom side of the board.
Postby AlbertoGP » Sat May 10, 2014 6:10 pm
AlbertoGP
