Parallella Community • View topic - Documentation on MOVTS/MOVFS encoding
Re: Documentation on MOVTS/MOVFS encoding
Postby timpart » Mon Dec 23, 2013 5:00 pm
I may be able to test experimental features. I'm happy writing Epiphany assembler. Presumably you don't expect them to cause any permanent damage to the chip if they don't work out?
Work can be hectic at times, leaving me tired in the evenings, so I don't always have as much time to spend on hobbies as I'd like to. Hopefully I'll have my boards by the end of January.
Postby alexrp » Sat Dec 28, 2013 7:10 pm
Andreas, one thing: In binutils, 0xF0410 is understood as "iab" by the assembler. Given that it's usable in assembly language, can you clarify what it is?
Similarly, 'memconfig' and 'memreserve' are understood by the assembler, but are not documented.
alexrp
Postby alexrp » Mon Dec 30, 2013 7:11 am
And another: In the 16-bit encoding, there is no M0-M1. Does this just mean that the register group is 0b00?
alexrp
Postby aolofsson » Thu Jan 02, 2014 4:00 am
Correct!
Postby alexrp » Sat Jan 11, 2014 6:11 pm
@aolofsson so is the "iab" register part of the user/kernel mode stuff, or something else? It's a supported register by the toolchain, so I need to have some idea how to handle it in my simulator. If it's part of the user/kernel mode stuff, I can wait, though.
alexrp
Postby mhonman » Sat Jan 11, 2014 11:17 pm
Re experimental feature testing, I'm also up for that!
mhonman
Postby aolofsson » Wed Jan 15, 2014 3:47 am
Postby alexrp » Wed Jan 15, 2014 4:35 am
OK, thanks! I'll just simply make it a reserved register area in my simulator.
alexrp
Postby mhonman » Wed Jan 15, 2014 9:37 am
mhonman
