Parallella Community • View topic - Ubuntu Tips
Ubuntu Tips
Ubuntu Tips
Postby shodruk » Wed Dec 25, 2013 12:39 pm
Ubuntu Tips, Settings, Issues and Solutions, etc.
Re: Ubuntu Tips
Postby shodruk » Wed Dec 25, 2013 12:47 pm
The issue:
Serious audio latency
The solution:
Just uninstall PulseAudio
$ sudo apt-get purge pulseaudio
The side effect:
Unable to adjust audio volume from desktop
(use TV volume!)
No sound mixing
Re: Ubuntu Tips
Postby aolofsson » Wed Dec 25, 2013 1:27 pm
Thanks! We'll definitely fix this for default image going forward.
Re: Ubuntu Tips
Postby magorian » Wed Dec 25, 2013 9:26 pm
Andreas:
I find that the boards are running extremely hot even with the heatsinks on the Zincs (might as well preinstall those): even the edges of the boards and the standoffs are too hot to touch. One built from same image keeps hanging, very possibly from overheating. I can see why you needed 3A supplies! Do any of the environmental packages work reporting temps, and did you end up fan cooling all your prototypes? Thanks.
Dan
magorian
Re: Ubuntu Tips
Postby aolofsson » Wed Dec 25, 2013 9:48 pm
Dan,
We ran some boards for 24 hours without the need Let's open a new topic under the Parallella board sub forum and I will elaborate in exactly what we ran and measured in terms if power consumption.
Re: Ubuntu Tips
Postby ed2k » Thu Dec 26, 2013 12:54 am
it maybe easier to run all your development (editing, gui, compiling, building) directly from parallella board. but for serious development arm cpu with micro sd is slow and fragile comparing to harddisk based x86-64 PC. Especially ubuntu distro is not optimized parallella. so consider using a cross-development platform.
ed2k
Re: Ubuntu Tips
Postby shodruk » Thu Dec 26, 2013 12:03 pm
Are you using Eclipse?
Re: Ubuntu Tips
Postby ed2k » Thu Dec 26, 2013 7:01 pm
no I am not trying to run any graphical stuff on the gen1 board. my experience is mostly on the zedboard. I guess the ext file system is not suitable for the sd card.
ed2k
Re: Ubuntu Tips
Postby over9000 » Thu Dec 26, 2013 7:21 pm
over9000
Re: Ubuntu Tips
Postby shodruk » Thu Jan 02, 2014 8:54 pm
* Obsoleted. This tips is only for older kernels.
The issue:
On Parallella16_z7020wGPIO_131220.img(also ~1224.zip), X won't run.
quick fix:
Press Ctrl+Alt+F2 and login.
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.bak
sudo reboot
Return to Linux/U-Boot
Users browsing this forum: No registered users and 66 guests
