Example: In-line maths calculation, in internal memory
Moderator: Dr.BeauWebber
Re: Example: In-line maths calculation, in internal memory
Postby Dr.BeauWebber » Tue Jun 25, 2013 9:09 am
Thanks, no, as I say this was not the "compile for real hardware" version, just an aplcc compile to e-run.
I will now create a "real hardware version" on a Raspberry Pi - I have aplc running there, and I have built the latest gcc toolchain there, but not yet built an aplc to use that tool-chain.
Hopefully later today, but I still have urgent jobs for last Sunday still to do.
Dr.BeauWebber
Postby ysapir » Tue Jun 25, 2013 12:11 pm
So... could you do the same analysis on the version that took you 10s to run on the real board?
ysapir
Postby Dr.BeauWebber » Tue Jun 25, 2013 4:19 pm
OK, that is done :
As I no longer have access to the Parallella hardware :
I have built the latest gcc tool-chain on a Raspberry Pi, and copied on esdk.4.13.03.30.
Two things :
Firstly : this tool-chain allows me to generate a.out files that emit output on the arm :
$ /home/jbww/Src/Git/INSTALL/bin/e-run a.out
2.718146
(with the older sdk installation on the Parallella board, there is no output from the arm code using e-run)
Secondly, with the addition of links to the esdk, this installation builds the Epiphanny run time code.
I attach the requested dump and trace files.
The trace file all appears to be in low memory, here is a short section :
0x000234 ---   _epiphany_star  mov.l r1,0x4960   - registers <- 0x4960
0x000238 ---   _epiphany_star  movt r1,0x0       - registers <- 0x4960
0x00023c ---   _epiphany_star  mov.b r2,0x0      - registers <- 0x0
0x00023e ---   _epiphany_star  mov.b r3,0x0      - registers <- 0x0
0x000240 ---   _epiphany_star  strd r2,[r0],+0x1 - memaddr <- 0x46f0, memory <- 0x0, memaddr <- 0x46f4, memory <- 0x0, registers <- 0x46f8
0x000244 ---   _epiphany_star  sub r5,r1,r0      - cbit <- 0x1, vbit <- 0x0, vsbit <- 0x0, registers <- 0x268, zbit <- 0x0, nbit <- 0x0
0x000246 ---   _epiphany_star  bne.s 0x00000240  - pc <- 0x240
0x000240 ---   _epiphany_star  strd r2,[r0],+0x1 - memaddr <- 0x46f8, memory <- 0x0, memaddr <- 0x46fc, memory <- 0x0, registers <- 0x4700
0x000244 ---   _epiphany_star  sub r5,r1,r0      - cbit <- 0x1, vbit <- 0x0, vsbit <- 0x0, registers <- 0x260, zbit <- 0x0, nbit <- 0x0
0x000240 ---   _epiphany_star  strd r2,[r0],+0x1 - memaddr <- 0x4700, memory <- 0x0, memaddr <- 0x4704, memory <- 0x0, registers <- 0x4708
0x000244 ---   _epiphany_star  sub r5,r1,r0      - cbit <- 0x1, vbit <- 0x0, vsbit <- 0x0, registers <- 0x258, zbit <- 0x0, nbit <- 0x0
This uses aplc.ldf, which is based on fast.ldf
cheers, Beau
trace.tar.gz
New trace file
(1.48 KiB) Downloaded 469 times
dump.tar.gz
New dump file
(2.69 MiB) Downloaded 481 times
Last edited by Dr.BeauWebber on Tue Jun 25, 2013 4:31 pm, edited 2 times in total.
Reason: add information
Dr.BeauWebber
Return to APL
