Parallella Community • View topic - nfs mount and tftp boot
Postby ed2k » Tue May 28, 2013 3:06 am
My SD card is corrupted. If there is a network boot image probably the FS can live longer.
Have anyone made a network boot image?
ed2k
Re: nfs mount and tftp boot
Postby 9600 » Tue May 28, 2013 10:05 am
Postby ed2k » Wed May 29, 2013 4:53 am
ed2k
Postby 9600 » Wed May 29, 2013 4:47 pm
I'm unable to test this with a ZedBoard right now but I would have expected switching from a root filesystem on SD card to one on an NFS drive to be a simple matter of U-boot config/commands. E.g. see:
http://www.stlinux.com/u-boot/kernel-booting
If you're saying that the default U-boot doesn't have NFS support I'd suggest building it from source (and thus a new BOOT.BIN) and during the process of which checking to ensure that NFS is configured. Start from:
http://www.adapteva.com/white-papers/bu ... -platform/
Postby tomazb » Thu May 30, 2013 5:32 pm
On the Zedboard you have to change the kernel boot parameters in the devicetree, it should be the same with Parallella. Change the bootarg and compile device tree as described under "Device Tree Generation" http://www.adapteva.com/white-papers/bu ... a-platform. I'll try the nfsroot as soon as I get my Parallella board, in a month or so...
tomazb
Postby 9600 » Fri May 31, 2013 8:42 am
Postby tomazb » Fri May 31, 2013 10:52 am
tomazb
Postby ed2k » Sun Jun 02, 2013 12:04 am
just learned the kernel from ftp site does support nfsv3
however it requires command like this to work
mount -t nfs 192.168.0.250:/home/me /home/root -o rw,nolock,addr=192.168.0.250
ed2k
Postby shogunx » Thu Jul 17, 2014 6:44 pm
https://plus.google.com/107439537313305 ... 5taMhPKurp
I made a short tutorial on netbooting the Parallella. I hope this is useful for anyone looking to tftp/nfs boot their cluster nodes.
shogunx
Postby aolofsson » Thu Jul 17, 2014 10:24 pm
Brilliant!!
Return to Linux/U-Boot
