Parallella Community • View topic - creating a output register/interrup from PL to arm processor
Postby dipin » Tue May 29, 2018 12:30 pm
hi,
finally i successfully implemented this project and added a counter. now output of the adder is printing in the Ubuntu terminal. Here i need an extra control signal or register to give some control to the total design. when the counter reaches a particular value, i need to give a signal to arm processor. so anybody know how to how to add and extra output reg to above design ?
any help is really appreciated
thanks and regards
dipin divakar
dipin
Re: creating an extra output register from PL to arm process
Postby dipin » Wed May 30, 2018 12:16 pm
hi,
what i am trying to do is an interrupt which will goes from fpga to arm processor.. if anybody had any clue please help...
i can give it to the zynq processor by enabling the interrupt option. but how can i acess it in the arm processor
thanks in advance
dipin
Postby olajep » Fri Jun 08, 2018 2:26 pm
Re: creating a output register/interrup from PL to arm proce
Postby dipin » Tue Jun 12, 2018 4:32 am
HI,
thanks for the replay olajep :)
i connected the my interrupt to zynq processor IRQ_F2P pin. and i am using this c program to get the interrupt working. but my problem is the xil_drivers .my drivers are throwing error .
now how can i get the interrupt in arm side of the parallella board . which drivers are required for it. Is it xilinx drivers or we need to write our on ??
did parallella will supply some interface for this?
please share your views
thanks and regards
dipin
Postby olajep » Wed Jun 13, 2018 6:18 pm
Postby dipin » Fri Jun 29, 2018 9:42 am
dipin
Postby cpantel » Thu Sep 06, 2018 11:09 pm
cpantel
Postby dipin » Fri Oct 05, 2018 5:17 am
HI,
If you tell me what is the problem you are finding, i can help you
hints:: you have to use the old version of vivado.. 15.2 or 15.4 i think...
else the ip will show as a black box (because it will be empty if you uses the script).
if you are using 15.4, again you have to change the script file to 15.4 from 15.2.
then in the program, you have to change to "dev/epiphany" to "dev/mem"
then only it will map to fpga memory.
thanks and regards
dipin
Postby cpantel » Mon Oct 08, 2018 1:40 am
Hi dipin
please look this thread:
viewtopic.php?f=49&t=3411
I have used both 15.2 and 15.4
Thank you
cpantel
Postby dipin » Mon Oct 08, 2018 4:46 am
now what was the problem you are facing, same as in the post you mentioned .
thanks
dipin
Users browsing this forum: No registered users and 67 guests
