FPGA Accelerator
FPGA Accelerator
Postby promach » Tue Jan 03, 2017 7:47 am
I am having error http://paste2.org/ZtgJm29N with https://www.parallella.org/2016/01/21/creating-an-fpga-accelerator-in-15-minutes/ . Anyone ?
The error is due to the "WARNING: [Synth 8-115] binding instance 'system_i' in module 'system_wrapper' to reference 'system' which has no pins
INFO: [Synth 8-256] done synthesizing module 'system_wrapper' (2#1) [/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hdl/system_wrapper.v:12]"
[promach@localhost oh]$ cd src/accelerator/fpga/
[promach@localhost fpga]$ ./build.sh
rm: cannot remove 'system_wrapper.bit.bin': No such file or directory
rm: cannot remove 'bit2bin.bin': No such file or directory
****** Vivado v2016.2 (64-bit)
**** SW Build 1577090 on Thu Jun 2 16:32:35 MDT 2016
**** IP Build 1577682 on Fri Jun 3 12:00:54 MDT 2016
** Copyright 1986-2016 Xilinx, Inc. All Rights Reserved.
source package.tcl
# source ./ip_params.tcl
## set design axi_accelerator
## set projdir ./
## set root "../.."
## set partname "xc7z020clg400-1"
## set hdl_files [list \
## $root/accelerator/hdl \
## $root/common/hdl/ \
## $root/emesh/hdl \
## $root/emmu/hdl \
## $root/axi/hdl \
## $root/emailbox/hdl \
## $root/edma/hdl \
## $root/elink/hdl \
## set ip_files []
## set constraints_files []
# source ../../common/fpga/create_ip.tcl
## create_project -force $design $projdir -part $partname
## set_property target_language Verilog [current_project]
## set_property source_mgmt_mode None [current_project]
## if {[string equal [get_filesets -quiet sources_1] ""]} {
## create_fileset -srcset sources_1
## add_files -norecurse -fileset [get_filesets sources_1] $hdl_files
## set_property top $design [get_filesets sources_1]
## if {[string equal [get_filesets -quiet constraints_1] ""]} {
## create_fileset -constrset constraints_1
## if {[llength $constraints_files] != 0} {
## add_files -norecurse -fileset [get_filesets constraints_1] $constraints_files
## if {[llength $ip_files] != 0} {
## #Add to fileset
## add_files -norecurse -fileset [get_filesets sources_1] $ip_files
## #Set mode for IP
## foreach file $ip_files {
## #TODO: is this needed?
## set file_obj [get_files -of_objects [get_filesets sources_1] $file]
## set_property "synth_checkpoint_mode" "Singular" $file_obj
## #RERUN/UPGRADE IP
## upgrade_ip [get_ips]
## ipx::package_project -import_files -force -root_dir $projdir
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_clockgate.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_abs.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_pwr_isohi.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_iddr.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_datagate.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_delay.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_pwr_isolo.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux2.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux12.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_crc.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux8.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_add.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_shifter.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_8b10b_decode.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_8b10b_encode.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_csa92.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_pwr_buf.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_lat0.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_csa62.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_tristate.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_pulse2pulse.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_clockdiv.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/cfg_generic.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_crc32_64b.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_stretcher.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_gray2bin.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_ser2par.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_rsync.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_counter.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_csa42.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_reg0.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_edge2pulse.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux4.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_bitreverse.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_crc32_8b.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_pll.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_reg1.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_oddr.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_standby.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_fifo_async.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_bin2gray.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux6.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_par2ser.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_rise2pulse.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_fall2pulse.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_fifo_cdc.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_lat1.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_debouncer.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux9.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_bin2onehot.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_clockmux.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_edgedetect.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_7seg_decode.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_parity.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_memory_sp.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_fifo_generic.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_csa32.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_clockor.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux5.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux7.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_pwr_gate.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_mux3.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_buffer.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/common/hdl/oh_edgealign.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/emesh/hdl/emesh_constants.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/emesh/hdl/emesh_rdalign.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/emesh/hdl/ememory.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/emesh/hdl/emesh_wralign.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/emesh/hdl/emesh_if.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/emesh/hdl/emesh_readback.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/emmu/hdl/emmu.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/emailbox/hdl/emailbox_regmap.vh'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/emailbox/hdl/emailbox.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/edma/hdl/edma_dp.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/edma/hdl/edma_regs.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/edma/hdl/edma.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/edma/hdl/edma_ctrl.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/edma/hdl/edma_regmap.vh'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/erx.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/etx_arbiter.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/ecfg_if.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/axi_elink.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/etx_core.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/etx_clocks.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/erx_clocks.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/elink_constants.vh'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/erx_protocol.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/elink_cfg.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/erx_io.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/elink_regmap.vh'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/etx.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/etx_fifo.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/erx_remap.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/etx_remap.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/erx_arbiter.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/erx_core.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/erx_fifo.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/etx_io.v'.
WARNING: [IP_Flow 19-3833] Unreferenced file from the top module is not packaged: '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/elink/hdl/elink.v'.
INFO: [Common 17-14] Message 'IP_Flow 19-3833' appears 100 times and further instances of the messages will be disabled. Use the Tcl command set_msg_config to change the current settings.
WARNING: [IP_Flow 19-3899] Cannot get the environment domain name variable for the component vendor name. Setting the vendor name to 'user.org'.
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1704] No user IP repositories specified
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/opt/Xilinx/Vivado/2016.2/data/ip'.
CRITICAL WARNING: [HDL 9-870] Macro <CFG_ASIC> is not defined. [src/oh_memory_dp.v:36]
CRITICAL WARNING: [HDL 9-806] Syntax error near ";". [src/oh_memory_dp.v:36]
CRITICAL WARNING: [HDL 9-806] Syntax error near ";". [src/oh_dsync.v:18]
INFO: [IP_Flow 19-1842] HDL Parser: Found include file "src/accelerator_regmap.vh" from the top-level HDL file.
INFO: [IP_Flow 19-2228] Inferred bus interface 'm_axi' of definition 'xilinx.com:interface:aximm:1.0'.
INFO: [IP_Flow 19-2228] Inferred bus interface 's_axi' of definition 'xilinx.com:interface:aximm:1.0'.
INFO: [IP_Flow 19-4753] Inferred signal 'reset' from port 's_axi_aresetn' as interface 's_axi_aresetn'.
INFO: [IP_Flow 19-4728] Bus Interface 's_axi_aresetn': Added interface parameter 'POLARITY' with value 'ACTIVE_LOW'.
INFO: [IP_Flow 19-4753] Inferred signal 'reset' from port 'm_axi_aresetn' as interface 'm_axi_aresetn'.
INFO: [IP_Flow 19-4728] Bus Interface 'm_axi_aresetn': Added interface parameter 'POLARITY' with value 'ACTIVE_LOW'.
INFO: [IP_Flow 19-4753] Inferred signal 'interrupt' from port 'irq' as interface 'irq'.
INFO: [IP_Flow 19-4728] Bus Interface 'irq': Added interface parameter 'SENSITIVITY' with value 'LEVEL_HIGH'.
INFO: [IP_Flow 19-4753] Inferred signal 'clock' from port 'sys_clk' as interface 'sys_clk'.
INFO: [IP_Flow 19-818] Not transferring value dependency attribute "((2 * spirit:decode(id('MODELPARAM_VALUE.AW'))) + 40)" into user parameter "PW".
## ipx::remove_memory_map {s_axi} [ipx::current_core]
## ipx::add_memory_map {s_axi} [ipx::current_core]
## ipx::associate_bus_interfaces -busif s_axi -clock sys_clk [ipx::current_core]
INFO: [IP_Flow 19-4728] Bus Interface 'sys_clk': Added interface parameter 'ASSOCIATED_BUSIF' with value 's_axi'.
## ipx::associate_bus_interfaces -busif m_axi -clock sys_clk [ipx::current_core]
WARNING: command 'get_bus_interface' will be removed in the 2015.3 release, use 'get_bus_interfaces' instead
## set_property slave_memory_map_ref {s_axi} [ipx::get_bus_interface s_axi [ipx::current_core]]
WARNING: command 'get_memory_map' will be removed in the 2015.3 release, use 'get_memory_maps' instead
## ipx::add_address_block {axi_lite} [ipx::get_memory_map s_axi [ipx::current_core]]
WARNING: command 'get_address_block' will be removed in the 2015.3 release, use 'get_address_blocks' instead
## set_property range {65536} [ipx::get_address_block axi_lite \
## [ipx::get_memory_map s_axi [ipx::current_core]]]
## set_property vendor {www.parallella.org} [ipx::current_core]
## set_property library {user} [ipx::current_core]
## set_property taxonomy {{/AXI_Infrastructure}} [ipx::current_core]
## set_property vendor_display_name {ADAPTEVA} [ipx::current_core]
## set_property company_url {www.parallella.org} [ipx::current_core]
## set_property supported_families { \
## {virtex7} {Production} \
## {qvirtex7} {Production} \
## {kintex7} {Production} \
## {kintex7l} {Production} \
## {qkintex7} {Production} \
## {qkintex7l} {Production} \
## {artix7} {Production} \
## {artix7l} {Production} \
## {aartix7} {Production} \
## {qartix7} {Production} \
## {zynq} {Production} \
## {qzynq} {Production} \
## {azynq} {Production} \
## } [ipx::current_core]
WARNING: [IP_Flow 19-4623] Unrecognized family virtex7. Please verify spelling and reissue command to set the supported files.
WARNING: [IP_Flow 19-4623] Unrecognized family qvirtex7. Please verify spelling and reissue command to set the supported files.
WARNING: [IP_Flow 19-4623] Unrecognized family kintex7. Please verify spelling and reissue command to set the supported files.
WARNING: [IP_Flow 19-4623] Unrecognized family kintex7l. Please verify spelling and reissue command to set the supported files.
WARNING: [IP_Flow 19-4623] Unrecognized family qkintex7. Please verify spelling and reissue command to set the supported files.
WARNING: [IP_Flow 19-4623] Unrecognized family qkintex7l. Please verify spelling and reissue command to set the supported files.
WARNING: [IP_Flow 19-4623] Unrecognized family artix7. Please verify spelling and reissue command to set the supported files.
WARNING: [IP_Flow 19-4623] Unrecognized family artix7l. Please verify spelling and reissue command to set the supported files.
WARNING: [IP_Flow 19-4623] Unrecognized family aartix7. Please verify spelling and reissue command to set the supported files.
WARNING: [IP_Flow 19-4623] Unrecognized family qartix7. Please verify spelling and reissue command to set the supported files.
## ipx::archive_core [concat $design.zip] [ipx::current_core]
## exit
INFO: [Common 17-206] Exiting Vivado at Tue Jan 3 15:11:58 2017...
source run.tcl
# source ./run_params.tcl
## set design system
## set projdir ./
## set ip_repos [list "."]
## set hdl_files []
# source ../../common/fpga/system_init.tcl
## set report_dir $projdir/reports
## set results_dir $projdir/results
## if ![file exists $report_dir] {file mkdir $report_dir}
## if ![file exists $results_dir] {file mkdir $results_dir}
## set other_repos [get_property ip_repo_paths [current_project]]
## set_property ip_repo_paths "$ip_repos $other_repos" [current_project]
## update_ip_catalog
INFO: [IP_Flow 19-1700] Loaded user IP repository '/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga'.
## create_bd_design "system"
Wrote : </home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/system.bd>
## source $projdir/system_bd.tcl
### namespace eval _tcl {
### proc get_script_folder {} {
### set script_path [file normalize [info script]]
### set script_folder [file dirname $script_path]
### return $script_folder
### variable script_folder
### set script_folder [_tcl::get_script_folder]
### set scripts_vivado_version 2016.2
### set current_vivado_version [version -short]
### if { [string first $scripts_vivado_version $current_vivado_version] == -1 } {
### puts ""
### catch {common::send_msg_id "BD_TCL-109" "ERROR" "This script was generated using Vivado <$scripts_vivado_version> and is being run in <$current_vivado_version> of Vivado. Please run the script in Vivado <$scripts_vivado_version> then open the design in Vivado <$current_vivado_version>. Upgrade the design by running \"Tools => Report => Report IP Status...\", then run write_bd_tcl to create an updated script."}
### return 1
### set list_projs [get_projects -quiet]
### if { $list_projs eq "" } {
### create_project project_1 myproj -part xc7z020clg400-1
### set design_name system
### set errMsg ""
### set nRet 0
### set cur_design [current_bd_design -quiet]
### set list_cells [get_bd_cells -quiet]
### if { ${design_name} eq "" } {
### # USE CASES:
### # 1) Design_name not set
### set errMsg "Please set the variable <design_name> to a non-empty value."
### set nRet 1
### } elseif { ${cur_design} ne "" && ${list_cells} eq "" } {
### # USE CASES:
### # 2): Current design opened AND is empty AND names same.
### # 3): Current design opened AND is empty AND names diff; design_name NOT in project.
### # 4): Current design opened AND is empty AND names diff; design_name exists in project.
### if { $cur_design ne $design_name } {
### common::send_msg_id "BD_TCL-001" "INFO" "Changing value of <design_name> from <$design_name> to <$cur_design> since current design is empty."
### set design_name [get_property NAME $cur_design]
### common::send_msg_id "BD_TCL-002" "INFO" "Constructing design in IPI design <$cur_design>..."
### } elseif { ${cur_design} ne "" && $list_cells ne "" && $cur_design eq $design_name } {
### # USE CASES:
### # 5) Current design opened AND has components AND same names.
### set errMsg "Design <$design_name> already exists in your project, please set the variable <design_name> to another value."
### set nRet 1
### } elseif { [get_files -quiet ${design_name}.bd] ne "" } {
### # USE CASES:
### # 6) Current opened design, has components, but diff names, design_name exists in project.
### # 7) No opened design, design_name exists in project.
### set nRet 2
### } else {
### # USE CASES:
### # 8) No opened design, design_name not in project.
### # 9) Current opened design, has components, but diff names, design_name not in project.
### common::send_msg_id "BD_TCL-003" "INFO" "Currently there is no design <$design_name> in project, so creating one..."
### create_bd_design $design_name
### common::send_msg_id "BD_TCL-004" "INFO" "Making design <$design_name> as current_bd_design."
### current_bd_design $design_name
INFO: [BD_TCL-2] Constructing design in IPI design <system>...
### common::send_msg_id "BD_TCL-005" "INFO" "Currently the variable <design_name> is equal to \"$design_name\"."
INFO: [BD_TCL-5] Currently the variable <design_name> is equal to "system".
### if { $nRet != 0 } {
### catch {common::send_msg_id "BD_TCL-114" "ERROR" $errMsg}
### return $nRet
### proc create_root_design { parentCell } {
### if { $parentCell eq "" } {
### set parentCell [get_bd_cells /]
### # Get object for parentCell
### set parentObj [get_bd_cells $parentCell]
### if { $parentObj == "" } {
### catch {common::send_msg_id "BD_TCL-100" "ERROR" "Unable to find parent cell <$parentCell>!"}
### return
### # Make sure parentObj is hier blk
### set parentType [get_property TYPE $parentObj]
### if { $parentType ne "hier" } {
### catch {common::send_msg_id "BD_TCL-101" "ERROR" "Parent <$parentObj> has TYPE = <$parentType>. Expected to be <hier>."}
### return
### # Save current instance; Restore later
### set oldCurInst [current_bd_instance .]
### # Set parent object as current
### current_bd_instance $parentObj
### # Create interface ports
### # Create ports
### # Create port connections
### # Create address segments
### # Restore current instance
### current_bd_instance $oldCurInst
### save_bd_design
### create_root_design ""
## make_wrapper -files [get_files $projdir/${design}.srcs/sources_1/bd/system/system.bd] -top
Verilog Output written to : /home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hdl/system.v
Verilog Output written to : /home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hdl/system_wrapper.v
## set top_wrapper $projdir/${design}.srcs/sources_1/bd/system/hdl/system_wrapper.v
## add_files -norecurse -fileset [get_filesets sources_1] $top_wrapper
## if {[llength $hdl_files] != 0} {
## if {[string equal [get_filesets -quiet constrs_1] ""]} {
## create_fileset -constrset constrs_1
## add_files -norecurse -fileset [get_filesets constrs_1] $constraints_files
# source ../../common/fpga/system_build.tcl
## validate_bd_design
INFO: [BD 5-320] Validate design is not run, since the design is already validated.
## write_bd_tcl -force ./system_bd.tcl
INFO: [BD 5-148] Tcl file written out </home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system_bd.tcl>.
INFO: [BD 41-1662] The design 'system.bd' is already validated. Therefore parameter propagation will not be re-run.
## remove_files -fileset sources_1 $projdir/${design}.srcs/sources_1/bd/system/hdl/system_wrapper.v
## add_files -fileset sources_1 -norecurse $projdir/${design}.srcs/sources_1/bd/system/hdl/system_wrapper.v
## if {[info exists oh_synthesis_options]} {
## puts "INFO: Synthesis with following options: $oh_synthesis_options"
## set_property -name {STEPS.SYNTH_DESIGN.ARGS.MORE OPTIONS} -value $oh_synthesis_options -objects [get_runs synth_1]
## launch_runs synth_1
Exporting to file /home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hw_handoff/system.hwh
Generated Block Design Tcl file /home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hw_handoff/system_bd.tcl
Generated Hardware Definition File /home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hdl/system.hwdef
[Tue Jan 3 15:12:07 2017] Launched synth_1...
Run output will be captured here: /home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.runs/synth_1/runme.log
## wait_on_run synth_1
[Tue Jan 3 15:12:07 2017] Waiting for synth_1 to finish...
*** Running vivado
with args -log system_wrapper.vds -m64 -mode batch -messageDb vivado.pb -notrace -source system_wrapper.tcl
source system_wrapper.tcl -notrace
Command: synth_design -top system_wrapper -part xc7z020clg400-1
Starting synth_design
Attempting to get a license for feature 'Synthesis' and/or device 'xc7z020'
INFO: [Common 17-349] Got license for feature 'Synthesis' and/or device 'xc7z020'
INFO: Launching helper process for spawning children vivado processes
INFO: Helper process launched with PID 32612
Starting RTL Elaboration : Time (s): cpu = 00:00:04 ; elapsed = 00:00:04 . Memory (MB): peak = 1006.043 ; gain = 124.121 ; free physical = 136 ; free virtual = 3622
INFO: [Synth 8-638] synthesizing module 'system_wrapper' [/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hdl/system_wrapper.v:12]
INFO: [Synth 8-638] synthesizing module 'system' [/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hdl/system.v:13]
INFO: [Synth 8-256] done synthesizing module 'system' (1#1) [/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hdl/system.v:13]
Finished RTL Elaboration : Time (s): cpu = 00:00:04 ; elapsed = 00:00:05 . Memory (MB): peak = 1045.480 ; gain = 163.559 ; free physical = 124 ; free virtual = 3582
Report Check Netlist:
| |Item |Errors |Warnings |Status |Description |
|1 |multi_driven_nets | 0| 0|Passed |Multi driven nets |
Finished RTL Optimization Phase 1 : Time (s): cpu = 00:00:04 ; elapsed = 00:00:05 . Memory (MB): peak = 1045.480 ; gain = 163.559 ; free physical = 124 ; free virtual = 3582
WARNING: [Project 1-486] Could not resolve non-primitive black box cell 'system' instantiated as 'system_i' [/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hdl/system_wrapper.v:16]
INFO: [Device 21-403] Loading part xc7z020clg400-1
INFO: [Project 1-570] Preparing netlist for logic optimization
Processing XDC Constraints
Initializing timing engine
Parsing XDC File [/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.runs/synth_1/dont_touch.xdc]
Finished Parsing XDC File [/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.runs/synth_1/dont_touch.xdc]
Completed Processing XDC Constraints
INFO: [Project 1-111] Unisim Transformation Summary:
No Unisim elements were transformed.
Constraint Validation Runtime : Time (s): cpu = 00:00:00 ; elapsed = 00:00:00 . Memory (MB): peak = 1337.918 ; gain = 0.000 ; free physical = 142 ; free virtual = 3432
Finished Constraint Validation : Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1337.918 ; gain = 455.996 ; free physical = 141 ; free virtual = 3431
Start Loading Part and Timing Information
Loading part: xc7z020clg400-1
Finished Loading Part and Timing Information : Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1337.918 ; gain = 455.996 ; free physical = 141 ; free virtual = 3431
Start Applying 'set_property' XDC Constraints
Applied set_property DONT_TOUCH = true for system_i. (constraint file auto generated constraint, line ).
Finished applying 'set_property' XDC Constraints : Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1337.918 ; gain = 455.996 ; free physical = 141 ; free virtual = 3431
Finished RTL Optimization Phase 2 : Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1337.918 ; gain = 455.996 ; free physical = 141 ; free virtual = 3431
Report RTL Partitions:
| |RTL Partition |Replication |Instances |
Start RTL Component Statistics
Detailed RTL Component Info :
Finished RTL Component Statistics
Start RTL Hierarchical Component Statistics
Hierarchical RTL Component report
Finished RTL Hierarchical Component Statistics
Start Part Resource Summary
Part Resources:
DSPs: 220 (col length:60)
BRAMs: 280 (col length: RAMB18 60 RAMB36 30)
Finished Part Resource Summary
Start Parallel Synthesis Optimization : Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1337.918 ; gain = 455.996 ; free physical = 139 ; free virtual = 3431
Start Cross Boundary Optimization
Finished Cross Boundary Optimization : Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1337.918 ; gain = 455.996 ; free physical = 139 ; free virtual = 3431
Finished Parallel Reinference : Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1337.918 ; gain = 455.996 ; free physical = 139 ; free virtual = 3431
Start Area Optimization
Finished Area Optimization : Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1337.918 ; gain = 455.996 ; free physical = 131 ; free virtual = 3423
Finished Parallel Area Optimization : Time (s): cpu = 00:00:11 ; elapsed = 00:00:12 . Memory (MB): peak = 1337.918 ; gain = 455.996 ; free physical = 131 ; free virtual = 3423
Start Timing Optimization
Start Applying XDC Timing Constraints
Finished Applying XDC Timing Constraints : Time (s): cpu = 00:00:17 ; elapsed = 00:00:17 . Memory (MB): peak = 1354.902 ; gain = 472.980 ; free physical = 140 ; free virtual = 3386
Finished Timing Optimization : Time (s): cpu = 00:00:17 ; elapsed = 00:00:17 . Memory (MB): peak = 1354.902 ; gain = 472.980 ; free physical = 140 ; free virtual = 3386
Start Technology Mapping
Finished Technology Mapping : Time (s): cpu = 00:00:17 ; elapsed = 00:00:17 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 132 ; free virtual = 3378
Finished Parallel Technology Mapping Optimization : Time (s): cpu = 00:00:17 ; elapsed = 00:00:17 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 132 ; free virtual = 3378
Finished Parallel Synthesis Optimization : Time (s): cpu = 00:00:17 ; elapsed = 00:00:17 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 132 ; free virtual = 3378
Start IO Insertion
Start Flattening Before IO Insertion
Finished Flattening Before IO Insertion
Start Final Netlist Cleanup
Finished Final Netlist Cleanup
Finished IO Insertion : Time (s): cpu = 00:00:17 ; elapsed = 00:00:18 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 131 ; free virtual = 3377
Start Renaming Generated Instances
Finished Renaming Generated Instances : Time (s): cpu = 00:00:17 ; elapsed = 00:00:18 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 131 ; free virtual = 3377
Start Rebuilding User Hierarchy
Finished Rebuilding User Hierarchy : Time (s): cpu = 00:00:17 ; elapsed = 00:00:18 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 131 ; free virtual = 3377
Start Renaming Generated Ports
Finished Renaming Generated Ports : Time (s): cpu = 00:00:17 ; elapsed = 00:00:18 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 131 ; free virtual = 3377
Start Handling Custom Attributes
Finished Handling Custom Attributes : Time (s): cpu = 00:00:17 ; elapsed = 00:00:18 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 131 ; free virtual = 3377
Start Renaming Generated Nets
Finished Renaming Generated Nets : Time (s): cpu = 00:00:17 ; elapsed = 00:00:18 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 131 ; free virtual = 3377
Start Writing Synthesis Report
Report BlackBoxes:
| |BlackBox name |Instances |
|1 |system | 1|
Report Cell Usage:
| |Cell |Count |
|1 |system | 1|
Report Instance Areas:
| |Instance |Module |Cells |
|1 |top | | 0|
Finished Writing Synthesis Report : Time (s): cpu = 00:00:17 ; elapsed = 00:00:18 . Memory (MB): peak = 1363.918 ; gain = 481.996 ; free physical = 131 ; free virtual = 3377
Synthesis finished with 0 errors, 0 critical warnings and 1 warnings.
Synthesis Optimization Runtime : Time (s): cpu = 00:00:13 ; elapsed = 00:00:13 . Memory (MB): peak = 1363.918 ; gain = 104.434 ; free physical = 131 ; free virtual = 3377
Synthesis Optimization Complete : Time (s): cpu = 00:00:17 ; elapsed = 00:00:18 . Memory (MB): peak = 1363.926 ; gain = 482.004 ; free physical = 131 ; free virtual = 3377
INFO: [Project 1-571] Translating synthesized netlist
INFO: [Opt 31-138] Pushed 0 inverter(s) to 0 load pin(s).
INFO: [Common 17-83] Releasing license: Synthesis
13 Infos, 3 Warnings, 0 Critical Warnings and 0 Errors encountered.
synth_design completed successfully
synth_design: Time (s): cpu = 00:00:17 ; elapsed = 00:00:17 . Memory (MB): peak = 1364.918 ; gain = 410.457 ; free physical = 130 ; free virtual = 3377
report_utilization: Time (s): cpu = 00:00:00.01 ; elapsed = 00:00:00.01 . Memory (MB): peak = 1372.922 ; gain = 0.000 ; free physical = 129 ; free virtual = 3377
INFO: [Common 17-206] Exiting Vivado at Tue Jan 3 15:12:31 2017...
[Tue Jan 3 15:12:34 2017] synth_1 finished
wait_on_run: Time (s): cpu = 00:00:00.09 ; elapsed = 00:00:27 . Memory (MB): peak = 1070.695 ; gain = 8.000 ; free physical = 619 ; free virtual = 3868
## launch_runs impl_1
[Tue Jan 3 15:12:34 2017] Launched impl_1...
Run output will be captured here: /home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.runs/impl_1/runme.log
## wait_on_run impl_1
[Tue Jan 3 15:12:34 2017] Waiting for impl_1 to finish...
*** Running vivado
with args -log system_wrapper.vdi -applog -m64 -messageDb vivado.pb -mode batch -source system_wrapper.tcl -notrace
Design is defaulting to srcset: sources_1
Design is defaulting to constrset: constrs_1
INFO: [Project 1-479] Netlist was created with Vivado 2016.2
CRITICAL WARNING: [Project 1-486] Could not resolve non-primitive black box cell 'system' instantiated as 'system_i' [/home/promach/Documents/Grive/Personal/Digital/Parallella/oh/src/accelerator/fpga/system.srcs/sources_1/bd/system/hdl/system_wrapper.v:16]
Command: opt_design
Attempting to get a license for feature 'Implementation' and/or device 'xc7z020'
INFO: [Common 17-349] Got license for feature 'Implementation' and/or device 'xc7z020'
Running DRC as a precondition to command opt_design
Starting DRC Task
INFO: [DRC 23-27] Running DRC with 8 threads
ERROR: [DRC 23-20] Rule violation (INBB-3) Black Box Instances - Cell 'system_i' of type 'system_i/system' has undefined contents and is considered a black box. The contents of this cell must be defined for opt_design to complete successfully.
INFO: [Project 1-461] DRC finished with 1 Errors
INFO: [Project 1-462] Please refer to the DRC report (report_drc) for more information.
ERROR: [Vivado_Tcl 4-78] Error(s) found during DRC. Opt_design not run.
Time (s): cpu = 00:00:00.04 ; elapsed = 00:00:00.06 . Memory (MB): peak = 1280.484 ; gain = 66.031 ; free physical = 222 ; free virtual = 3489
INFO: [Common 17-83] Releasing license: Implementation
10 Infos, 0 Warnings, 1 Critical Warnings and 2 Errors encountered.
opt_design failed
ERROR: [Common 17-39] 'opt_design' failed due to earlier errors.
INFO: [Common 17-206] Exiting Vivado at Tue Jan 3 15:12:44 2017...
[Tue Jan 3 15:12:46 2017] impl_1 finished
wait_on_run: Time (s): cpu = 00:00:00.12 ; elapsed = 00:00:12 . Memory (MB): peak = 1070.695 ; gain = 0.000 ; free physical = 597 ; free virtual = 3865
## launch_runs impl_1 -to_step write_bitstream
[Tue Jan 3 15:12:46 2017] Launched impl_1...
[Tue Jan 3 15:12:46 2017] Waiting for impl_1 to finish...
INFO: [Common 17-206] Exiting Vivado at Tue Jan 3 15:12:46 2017...
[ERROR] : Can't read BIT file - ./system.runs/impl_1/system_wrapper.bit
cp: cannot stat 'system_wrapper.bit.bin': No such file or directory
promach
Re: FPGA Accelerator
Postby jvarred » Sun Apr 30, 2017 10:43 pm
Hi, I had the same problem and it solved after changing vivado version on system_bd.tcl file (https://github.com/parallella/oh/issues/98). I reccomend you to use the stable branch as it doesn't give those problems. Here are the steps that I used to make it work: https://github.com/parallella/oh/issues ... -298262178
jvarred
Postby promach » Fri Jun 09, 2017 9:00 am
I am using Vivado version 2017.1
I have followed the instructions in https://github.com/parallella/oh/issues/103#issuecomment-298262178, but I still have the following error.
Please see https://github.com/parallella/oh/issues/98 for further information.
error.txt
error log file
(30.98 KiB) Downloaded 1003 times
promach
Postby manojcs26 » Tue Sep 05, 2017 8:46 am
Even I'm facing the same issue...
I checked out the stable version and ran
./build.sh
To see the same error
And I noticed that the file 'system_bd.tcl' will be modified after I run build.sh.
Create Ports and Create Port Connections are gone(I assume, this is the reason for the above error).
I'm using Vivado 2015.4.
I would be really happy if someone helps me...
Im stuck with this error from almost 10 days
Thank you
manojcs26
Postby manojcs26 » Tue Sep 05, 2017 10:43 am
I corrected the error (forgot to change the version to 2015.4 in one of the file) and got the bitstream. now I copied that bitstream to the boot directory.
Im trying to run the test present in 'accelerator/sw/'. Im compiling the test files and creating hello.elf...
Now when I try to run the executable It gives an error saying
f_map no such file exists
segmentation fault
I dont know what is the problem..
Any help would be appreciated....
Thank you
manojcs26
Postby olajep » Tue Sep 05, 2017 3:20 pm
manojcs26 wrote:I corrected the error (forgot to change the version to 2015.4 in one of the file) and got the bitstream. now I copied that bitstream to the boot directory.
segmentation fault
Thank you
I'm guessing the accelerator example uses an old Parabuntu image (pre 2015.1 (??)) with the old epiphany driver.
Change /dev/epiphany to /dev/mem here:
https://github.com/parallella/oh/blob/7 ... iver.c#L70
https://github.com/parallella/oh/blob// ... iver.c#L70
You need to run the program as root (e.g., use sudo) now.
Debugging segfaults 101:
Pass -ggdb -g3 to gcc
$ gdb myprogram.elf
(gdb) run
Starting program: /tmp/a.out
Program received signal SIGSEGV, Segmentation fault.
0x0000000000400500 in bar () at myprogram.c:4
5       *p = 123;
(gdb) backtrace
#0  0x0000000000400500 in bar () at myprogram.c:5
#1  0x000000000040051b in quux () at myprogram.c:12
#2  0x000000000040052b in main () at myprogram.c:17
(gdb) print p
$1 = (int *) 0x0
[[so in this example it was a zero pointer dereference]]
(gdb) quit
Tyr to disable compiler optimizations if you get a nonsensical backtrace.
HTH,
Ola
