Parallella Community • View topic - Data transfer between epiphany cores
Postby gordon » Mon Jun 05, 2017 6:56 am
I am writing a program for eigenvalue decomposition of a matrix. For this case I am dividing the work to the 16 epiphany cores using eSDK. But by algorithm involves the data transfer between the cores. I am first running a device program say "epipany_task1" only on the diagonal cores of the epiphany module. The program returns four float values each from one core. Now I need to send these float values to other non diagonal cores to be inputted for another function say "epiphany_task2" which runs on the non diagonal cores after "wpiphany_task1" has finished running on all four diagonal cores.Each non diagonal core gets two float values, one from the row diagonal core and other from column diagonal core.Is there an external memory accessible to the epiphany cores from where I can write these float values and later read them. Or can I read the float values to host processor and then write them to the non diagonal cores in the host code?
Thanks in advance! :)
gordon
Re: Data transfer between epiphany cores
Postby sebraa » Mon Jun 05, 2017 9:53 am
All cores share the same address space, so you can just generate a pointer to some other core's memory and write your values there (make sure you understand the special properties of such accesses, and where you may need a 'volatile' keyword).
You can use shared memory to communicate data between the cores, but the performance is extremely bad. Don't do it.
Postby gordon » Tue Jun 06, 2017 4:24 am
What special accesses are you exactly referring to? Since each core has its own 32KB of memory, how do I specify a pointer say *a to a particular core say with core_id(2,0). I can e_write the pointer to the memory address in host program, but how do I use it in the device program? Can you please elaborate a little. Thanks!
gordon
Postby sebraa » Tue Jun 06, 2017 9:09 pm
