Parallella Community • View topic - USB Issue Troubleshooting
Re: USB Issue Troubleshooting
Postby lanscene » Fri Nov 06, 2015 5:43 am
I think Adapteva folks use the same power supply/USB hub/cable to test the board,
So they can't reproduce the fault.
do they suppose all the people around the world should buy the same band peripheral?
BTW, I use SKU101020.
lanscene
Postby ajtravis » Fri Nov 06, 2015 10:07 am
Postby sting » Wed Feb 03, 2016 12:37 am
I am attempting to use the usb port for a real usb instrument device. I connect to this device using other boards, but can't with the parallella.
Whenever I try lsusb I get the message "unable t initialize libusb -99"
* Failure mode (sometimes or always?)
ALWAYS
* Headless/hdmi configuration
Headless
* FPGA/Linux/Ubuntu version being used
ubuntu-14.04-headless-z7010-20150130.1
* Fan used?
5V 0.09A 60 mm Fan
* SKU#
I can't see it, covered by case. Will remove it if I have to.
It is not from the kickstarter, and it is a desktop version
* Power supply used
5V 2.5A CUI
sting
Postby peteasa » Thu Jul 21, 2016 7:12 am
peteasa
Postby colestoc » Tue Feb 07, 2017 8:01 pm
Has the issue with the USB been resolved? I have a new Parallella-18 7010 board running the latest Ubuntu distribution. My USB intermittently worked with the first few tries, but now consistently fails to recognize the USB devices. I tried a couple of the USB workarounds, such as a powered hub, to no avail. The board responds fine in headless mode, so most of the functionality is there, but not the USB.
What is recommended as a fix, or does this mean I have a broken board? FYI, the heatsink has been installed, and I am using a fan.
colestoc
Postby mchampigny » Wed Feb 08, 2017 3:30 pm
It's not a broken board, or rather, it's not a problem that will be fixed by you getting a new board.
My USB only works with a powered USB hub. I've never managed to get passive USB working and I've tried several kinds of cables and passive hubs.
mchampigny
Postby abraxas3d » Wed Feb 08, 2017 10:57 pm
Cannot get USB working on Parallella kickstarter board regardless of how the devices are connected. Direct, powered hub, different powered hub, unpowered hub, doesn't matter.
parallella@parallella:~$ lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
parallella@parallella:~$ dmesg | grep -i ulpi
[ 1.155751] ULPI transceiver vendor/product ID 0x0424/0x0007
[ 1.160028] Found SMSC USB3320 ULPI transceiver.
[ 1.163401] ULPI integrity check: passed.
[ 1.206606] ULPI transceiver vendor/product ID 0x0424/0x0007
[ 1.210919] Found SMSC USB3320 ULPI transceiver.
[ 1.214181] ULPI integrity check: passed.
parallella@parallella:~$ uhd_usrp_probe
linux; GNU C++ version 4.9.2; Boost_105500; UHD_3.11.0.git-71-g2016126f
Error: LookupError: KeyError: No devices found for ----->
Empty Device Address
parallella@parallella:~$ uhd_find_devices
No UHD Devices Found
abraxas3d
Postby colestoc » Thu Feb 09, 2017 2:41 am
Thanks for the reply. I have been using a powered hub, a Sabrent model, to no avail. What type of powered hub are you using? Perhaps there is some issue with either power back-feeding or timing with specific cables that makes the initialization flaky.
colestoc
Postby marcofranchimoretti » Mon May 14, 2018 1:39 am
I have not been successful in getting USB working.
I first tried Headless then switched to the HDMI version which I've been using for most of my tests.
Linux Parabuntu [Last Linux ]
* Fan used?
No.
* SKU#
P1601-01, SN 0017115 (The large heatsink didn't make this easy).
* Power supply used
USB cable coming from a powerboard with USB power plugs. No indication of power problems.
I have tried
- Power cycling the board with and without each of the peripherals attached. Use Power Supply 5v 2.4A
The board boots every time.
I have not any success with USB.
USB notes:
I am using a USB adaptor. I've tried a number of peripherals:
- HUB USB Hamlet, Mcally, Tucano and other. Passive and not.
- Long Cable for USB Kb and Mouse.
- SanDisk USB drive
- USB sound card.
Cheers
marcofranchimoretti
Postby olajep » Thu May 17, 2018 9:38 am
Users browsing this forum: No registered users and 87 guests
