Linking object files
Postby snim2 » Sat Jun 27, 2015 1:18 am
I am assembling and linking some Epiphany assembler files like this:
epiphany-elf-as add.S -o add.o
epiphany-elf-ld -N -T $EPIPHANY_HOME/bsps/parallella_E16G3_1GB/internal.ldf add.o -static -o add.elf
which results in this error message:
epiphany-elf-ld: warning: cannot find entry symbol _start; defaulting to 0000000000000058
Do I really need a _start symbol in my assembler, or can I just use main? Or have I missed a library that the linker needs to know about?
Sarah
snim2
Re: Linking object files
Postby piotr5 » Sat Jun 27, 2015 8:03 am
as far as I know c-programs don't really start with the main procedure. before that libs are loaded and such. so also in assembler "main" has no meaning.
piotr5
Postby snim2 » Sat Jun 27, 2015 12:04 pm
That's extremely helpful, many thanks!
Sarah
snim2
Return to Assembly
