ShmName
ShmName
Postby Nader_Jendoubi » Mon Mar 16, 2015 11:24 am
Hi
in the "hello world" example:
what the following expressions are used for:
const char ShmName[] = "hello_shm";
e_shm_attach(&emem, ShmName);
e_shm_alloc(&mbuf, ShmName, ShmSize)
because i didn't find these 2 last functions in epiphany SDK manuel and the didn't understand the utility for ShmName
can i use e_alloc instead of these 2 functions???
Nader_Jendoubi
Re: ShmName
Postby skinner » Fri Jun 05, 2015 3:48 pm
Hi !
Did you ever find an answer to your question because I'm quite interrested myself to know in which case it is better to use e_alloc or e_shm_alloc ?
If not then at least I can say that e_shm_alloc has basically the same behaviour as e_alloc except that you give a name (a tag) to the shared memory space. This way you can "attach" yourself to this shared memory space by giving its name to e_shm_attach. As far as I understand, it allows us not to care about the offsets inside the shared area since there must be some hidden mechanism taking care of it with the tag/name system.
Thomas.
skinner
Re: ShmName
Postby etim » Tue Sep 29, 2015 9:30 am
I'm wondering this too. Is it like a key or pointer to a block of memory that is auto assigned?
etim
Users browsing this forum: No registered users and 55 guests
