Parallella Community • View topic - Harris corner detector and openCL
Moderator: dar
Postby Nader_Jendoubi » Wed Apr 08, 2015 9:09 pm
Hi
I'm very new in using openCL for Parallella
I expoited the sobel filter project available at the link https://github.com/sclukey/parallella-o ... 148f196f1b
and i write a kernel to realise a harris corner detector application : https://www.dropbox.com/s/64jjr76v2ulxd ... l.txt?dl=0
and i write the host code : https://www.dropbox.com/s/dv6nowou201v06p/host.txt?dl=0
in the kernel code i traduct the harris algorithm and i return the coordinates of a number of pixels used with the function cvcircle to draw circles around the harris points
when i compile the kernel with clcc, get this message : clmesg error: clcc.c(668) : clccl returned non-zero exit status
but i didn't get the .o file
i still don't know what is my fault.
Please i need some help with this code. Can anyone suggest to me any solutions??
Nader_Jendoubi
Re: Harris corner detector and openCL
Postby nickoppen » Thu Apr 09, 2015 10:41 am
Please post the whole of the clcc call and the compiler output please. There could be lot's of things wrong.
nickoppen
Postby Nader_Jendoubi » Thu Apr 09, 2015 2:09 pm
there was a lot of problems in the syntax of the code and i correct them all
i remember that some message with the kind of : e32-elf : no such file e32-objcopy : no such file but when i correct the syntax problems it disappears
when i compile, only that message shows and no file was generated.
Nader_Jendoubi
Postby Nader_Jendoubi » Thu Apr 09, 2015 4:25 pm
the clcc command is:
clcc -o device/bin/kernel.o -c device/src/kernel.c
Thanks for your help
Nader_Jendoubi
Postby nickoppen » Fri Apr 10, 2015 12:33 am
The coprthr_primer-1.6.0.pdf shows the syntax of clcc as:
clcc [options] file1.cl file2.cl ... [-o output.o]
Try putting the kernel files first and the output second.
Otherwise, see if the JIT compiler works.
nickoppen
Postby Nader_Jendoubi » Fri Apr 10, 2015 6:07 pm
I change the compile command but the same problem persists : Nothing generated
How can i know what kind of problem i made when nothing shows except the same problem??
Nader_Jendoubi
Postby Nader_Jendoubi » Fri Apr 10, 2015 6:09 pm
Can you please try to compile the code in your device and tell me what results do you get and what problems do you expect??
Nader_Jendoubi
Postby nickoppen » Sat Apr 11, 2015 12:05 am
Please provide working code. I get 16 syntax errors compiling the kernel downloaded from your dropbox.
nickoppen
Postby Nader_Jendoubi » Tue Apr 14, 2015 1:19 pm
Sorry for that friend
Here is the version of code without any syntax errors but the same problem is present, providing no bin file
https://www.dropbox.com/s/lgd50j3olq07t ... nel.c?dl=0
I can't figure out where the problem is, so please try to compile it and tell me your opinion
Nader
Nader_Jendoubi
Postby nickoppen » Thu Apr 16, 2015 12:04 pm
nickoppen
Return to OpenCL
