thank you all for the precious help, i found the script very useful.
I'm new to the parallella world, just received the board today!
i found really useful the script because i started connecting via Win the board and cant use the graphic interface.
with the heatsink provided i recorded pretty high temp even with idle board - 76°C.
- with heatsink only.
- zynq temp up no fan.JPG (10.78 KiB) Viewed 18448 times
i found some interesting post using a 5v fan but i'm not confortable with soldering..
so i used an old small case fan - 12v - connected to the pc power.
temperature dropped to 55.7 °C at idle.
- with 12v fan
- zynq temp up 12v fan.JPG (9.11 KiB) Viewed 18448 times
tomorrow i'll use an old 12v adapter from a notebook to make a dedicated power supply.
i'll also try the improved scripts.
sorry if i posted in the wrong place! noob deserve some patience
best regards.
FS.
