First step with parallella
Postby zodane » Fri Feb 13, 2015 10:56 am
I've just get my Parallella embedded platform. :D
But i have many issues.
I had never use ISE or Vivado, just some work with Modelsim.
also i'm new with zynq
So i start with the architecture of the zynq, then i've took a look in forum and in parallellagram (by the way, i give thanks to Yani Dubin). But i can't find a way to program the parallella (there is many new terms Github, Planahead,...)
If i should understand and get familiarized with ISE, isn't better to do that with Vivado!!
Could any one share a tutorial of using Vivado with Parallella?
If i use Vivado should i do that only with a JTAG?
If i use Vivado can i still able to program the epiphany, and use HDMI,... ?
Could the Parallella board work without an OS (ARM Programmed as a Microcontroller??)
Is there a version of RTOS that can run in Parallella?
zodane
Re: First step with parallella
Postby 9600 » Fri Feb 13, 2015 11:20 am
zodane wrote:Hi,
So many questions! Sounds like you probably don't want to be messing around with the FPGA and ISE/Vivado, and instead simply use the Epiphany SDK. That is, unless you're experienced in FPGA development and this is what you're particularly interested in.
Yes, this is possible, but I imagine some work would then be required in order to still access the Epiphany.
Yes, patc has a project which uses FreeRTOS, and there may be others.
Postby zodane » Fri Feb 13, 2015 2:34 pm
Thank you Andrew for replying (to some questions ;) )
I bought the Parallella for a big project, the porcupine wasn't available so i bought the connectors too. :)
- This is the first Parallella in my country (as i know) and if i can manage it to work with an pedagogical way it will be studied in my university
- I want to implement the results of my research (video processing) in the Parallella and write some paper about that, i just need to know how to start. So there is some co-design (epiphany+PS+PL) and all should work in a real time.
Actually this is not an option, so i have to work with one of them ISE or Vivado; and i prefer to work with Vivado is it that possible (only with Jtag?) can i still work with epiphany if i do so?
Regards
zodane
Postby 9600 » Fri Feb 13, 2015 3:02 pm
zodane wrote:This is the first Parallella in my country (as i know) and if i can manage it to work with an pedagogical way it will be studied in my university
Interesting. Can I ask where you are located? Just curious!
Right, so you do need to use the Xilinx tools. Wasn't sure at first if you had a simpler idea in mind that just required use of the eSDK.
The FPGA bitstream file lives on the BOOT volume of the Micro SD card and so you don't need to use JTAG to reconfigure this. If you want to still be able to use the Epiphany and/or HDMI, you will obviously need to extend one of the the existing projects. My understanding is that there remains some work still to be done before there is a fully functional flow for Vivado, although I could be wrong. ISE is certainly the more trodden path at this point in any case.
Look forward to hearing about your progress!
Postby zodane » Fri Feb 13, 2015 6:10 pm
and what make the board Boot from SD card?
zodane
Postby patc » Sat Feb 14, 2015 10:33 pm
just my 2 cents:
If you're willing to use the Zynq in standalone from scratch and at your own risk you can use Vivado. Else you have to wait for Adapteva to complete the move to Vivado
http://svenand.blogdrive.com/archive/16 ... N_EQU10xlY
but again, Zynq in standalone from scratch, no Epiphany. Check one of my previous posts for DDR settings. However you should also be aware that in such case the ISL9305 will default to 1.5V to SDRAM instead of 1.35V
yes
see previous
Absolutely, standard Cortex A9 stuff
As Andrew said, I'm using FreeRTOS and so far it seems to be working fine.
FSBL in QSPI flash
Postby 9600 » Sun Feb 15, 2015 11:12 am
FSBL in QSPI flash
And U-boot also.
Postby zodane » Mon Feb 16, 2015 7:30 am
Patc and Andrew thank you for clarification
Regards
zodane
Postby zodane » Wed Feb 18, 2015 12:06 pm
Now i'm starting with programmation the ARM cores using Xilinx SDK. :? :?
i have some issues
1- What should i select in Hardware platform (Xilinx SDK)
2- Once i have generate the program (supposed to run in ARM) how can i move it to parallella (UART, µSD,... ?)
Regards
zodane
Postby patc » Wed Feb 18, 2015 1:34 pm
I assume you're using Vivado and want to try the Hello_World example. May be you can try out the following:
- Make a Vivado project for your Parallella with the bare minimum (just UART1 MIO 8..9). Then generate the bitstream. You are NOT going to download the bitstream to the FPGA but you need the correct hardware platform to get SDK to generate the proper BSP (I'm using my own bistream but I assume this procedure should work as well with the Adapteva bistream as it is)
- switch to SDK
- New-Project-Hardware Platform Specification -> select previously created bitstream
- New-Application Project -> test with ps7_cortexa9_0, standalone and create new test_bsp
- select Hello World
- build test
- Run-Debug Configuration and New Xilinx C/C++ application (GDB)
- uncheck "Run ps7_init" and "Run ps7_post_config"
should be like the following:
Following operations will be performed before launching the debugger.
1. Reset processor.
2. 'C:\Users\pat\workspace2014_3_7020\test\Debug\test.elf' will be downloaded to the processor 'ps7_cortexa9_0'
- connect a terminal to your Parallella serial port (115200 bauds)
- then run it (JTAG to download to the Parallella)
