USB workaround
Re: USB workaround
Postby ESI » Tue Oct 14, 2014 11:09 pm
after many set backs (32bit arm-gcc on 64bit system, ISE under Linux), I managed to build a FSBL with ISE 14.7 which boots. Fortunately I can try and error with FSBLs because I have a JTAG connection (don't try this at home, if you cannot connect JTAG to reflash). But I did not yet patch the FSBL, because I ran out of time again. I will try and report, if I find time again, sorry....
Joerg
ESI
Re: USB workaround
Postby Sean S » Mon Nov 10, 2014 12:59 pm
So, it's has been many months since Adapteva finally admited that there was a problem... and many more months have gone by. What is the plan to fix this USB or give people their money back!?
:cry: :cry: :cry:
Sean S
Re: USB workaround
Postby Len » Mon Nov 17, 2014 5:29 pm
I haven't experienced this problem. Does it only occur if you are using the USB next to the power connecter? I have a powered Macally hub plugged into the one next to the HDMI and until I saw this thread I didn't know there was a problem. Both 2A wall warts are plugged into a switchable power cord. I use a wireless Logitech k330 keyboard and mouse and transfer files from USB sticks. My board is 7020 based from the kickstarter batch.
Len
Re: USB workaround
Postby ajtravis » Tue Nov 18, 2014 10:21 am
Re: USB workaround
Postby frostybeard » Wed Nov 26, 2014 8:05 am
So, it's been about half a year. Will there be a patch? Or an update?
frostybeard
Re: USB workaround
Postby Sean S » Fri Nov 28, 2014 1:01 pm
I think we can forget about this being fixed. It took ages to acknowledge that there was a problem and there is never a response as to when this will be fixed. Save yourself the frustration and throw the board in the bin and never buy anything from these guys again. Clearly they don't appreciate their loyal backers.
Sean S
Re: USB workaround
Postby ajtravis » Fri Nov 28, 2014 1:11 pm
Re: USB workaround
Postby frostybeard » Sun Nov 30, 2014 10:13 pm
Anything at all would be appreciated.
Joerg, if you want to share the sources of your FSBL, I am sure someone here could follow up on it. (I have zilch experience with Xilinx FSBLs)
FSBL= first stage bootloader, a Xilinx-specific bootloader.
frostybeard
Re: USB workaround
Postby aolofsson » Sun Nov 30, 2014 11:28 pm
In the latest version of Vivado, supposedly the first stage boot loader has been GPL'ed! Got it from a good source, but have yet to see the code with my own eyes.
Re: USB workaround
Postby timhavens » Wed Dec 03, 2014 2:28 am
BUMP
timhavens
Users browsing this forum: No registered users and 84 guests
