Parallella Community • View topic - Code::Blocks - Good alternative to eclipse
Re: Code::Blocks - Good alternative to eclipse
Postby nickoppen » Mon Nov 17, 2014 8:32 pm
Hi Andy,
The Brown Deer offline compiler, clcc calls the SDK and it seems to use the -g flag:
e-g++ -O0 -g -Wall -c -fmessage-length=0 -ffast-math -ftree-vectorize -funroll-loops -Wunused-variable -ffp-contract=fast -mlong-calls -mfp-mode=truncate -falign-loops=8 -falign-functions=8 -w -fstack-usage -fno-exceptions -U_FORTIFY_SOURCE -fno-stack-protector -I/opt/adapteva/esdk/tools/e-gnu/epiphany-elf/sys-include -fpermissive -D__coprthr_device__ -x c++ -I/usr/local/browndeer/include -D __xcl_kthr__ --include=e32pth_if_needham.h --include=opencl_lift.h --include=e32_opencl_ext.h -D __STDCL_KERNEL_VERSION__=020000 -D__COPRTHR__ -D E32_DRAM_ZEROPAGE=0x8e100000 -I/home/linaro/Work/ndfork -D __coprthr__ -S oWyBXV.cpp
execshell> cd /tmp/xclYwTdtI; e-g++ -O0 -g -Wall -c -fmessage-length=0 -ffast-math -ftree-vectorize -funroll-loops -Wunused-variable -ffp-contract=fast -mlong-calls-funr9
I create an elf file and then link it to the executable. The clnm utility seems to report the presence of symbols as well:
linaro-nano:~/Work/ndfork/bin/Debug> clnm ndfork.elf
clnm: '/home/linaro/Work/ndfork/ndfork.cl' bin [coprthr:ARMv7]
clnm: '/home/linaro/Work/ndfork/ndfork.cl' bin [coprthr:E16G Needham]
clnm: '/home/linaro/Work/ndfork/ndfork.cl' ksym k_callCount
clnm: '/home/linaro/Work/ndfork/ndfork.cl' src [<generic>]
code::blocks seems to be missing them somehow?
nick
nickoppen
Postby AndyC » Mon Nov 17, 2014 10:32 pm
Hi Nick,
I will have a look tomorrow for you....
Andy
AndyC
Postby AndyC » Tue Nov 18, 2014 2:55 pm
Hi Nick,
Sorry there was a step missing from my original post, I have edited that post to add a stage 13.
13. Settings->debugger->EGDB add the following line to "Debugger Initialisation Commands":
Load
It should work for you then (hopefully!).
Cheers
Andy
AndyC
Postby nickoppen » Wed Nov 19, 2014 6:34 am
Thanks Andy,
Unfortunately that has not done the trick.
I'm going to have to get my head around e-gdb so that I actually understand what I am doing rather than have wild stabs settings and values.
Could you post an executable that works for you so that I have something that I know will work. That's what lead to me getting over the last problem I had.
nick
nickoppen
Postby AndyC » Wed Nov 19, 2014 8:34 am
hello-world.tar.gz
(21.56 KiB) Downloaded 1569 times
AndyC
Postby nickoppen » Wed Nov 19, 2014 8:54 am
Thanks Andy that's great. Now I know what I am looking for.
I can see straight away that my load command is not working. I'll have a play over the next couple of days.
nick
nickoppen
Postby nickoppen » Thu Dec 11, 2014 6:38 am
Unfortunately I have not been able to get e-gdb going with OpenCL code at all.
But if anyone wants to see AndyC's procedure with screen shots, I've written it up here:
nick
nickoppen
Postby davidl » Wed Feb 18, 2015 6:41 pm
davidl
Postby AndyC » Wed Feb 18, 2015 7:45 pm
Hi David,
Well it look like it is not compiling your source to me.
What is the name of your source file?
Cheers
Andy
AndyC
Postby davidl » Wed Feb 18, 2015 8:20 pm
Greetings,
I've attached the script. It's a .c file
Thank you very much for your help
David
Epiphany_Hello.c
(330 Bytes) Downloaded 1587 times
davidl
